Ignition Switch Short?
Old Oct 22, 2021 | 01:41 PM
Patnlisa155's Avatar
Patnlisa155
4th Gear
Default Ignition Switch Short?
I just bought a 2006 Street Bob with 18,600 miles. When I turn the ignition on sometimes the lights and speedometer do not come on. If I jiggle the key a bit it works ok. What do I need? A new switch? Thanks.
Old Oct 22, 2021 | 01:52 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You might want to check the connector for the switch.
Not uncommon for switches to get wonky, especially after 15 years.
Some guys have disassembled ignition switches and got them working.
Avoid el cheapo aftermarket ignition switches.
Old Oct 22, 2021 | 08:53 PM
TexasScooterTrash's Avatar
TexasScooterTrash
You mean that goofy fork lock/ignition switch?? LOL Shoot a little WD-40 in it then turn the key through all of the positions. Switch contacts are copper and eventually, from the low mileage (lack of use) get corroded.
Old Oct 23, 2021 | 07:03 AM
Patnlisa155
4th Gear
Thank you.
Old Oct 23, 2021 | 07:04 AM
Patnlisa155
4th Gear
Thanks! I’ll do it now.
Old Oct 23, 2021 | 07:09 AM
RANGER73's Avatar
RANGER73
WD40 won't clean the contacts. Either disassemble it to clean it properly or replace it.
Old Oct 23, 2021 | 08:33 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Oh, and it is not a short...
Old Oct 23, 2021 | 04:35 PM
Patnlisa155
4th Gear
I think the WD40 worked. I haven’t had a problem since. Fingers crossed.
Old Oct 23, 2021 | 04:36 PM
Patnlisa155
4th Gear
I’m a Navy veteran too. 1968-74. YN2. I was in VF-101 in 1969-71.
Old Oct 25, 2021 | 11:44 AM
Patnlisa155
4th Gear
I tried the WD40 and I have not had a problem since! Turn the key and everything works every time. Thank you.
danimal212
Oct 20, 2017 06:33 PM
bosshoss41
May 4, 2012 08:20 AM
rebbe18
Mar 25, 2012 08:01 PM
two tall
Apr 1, 2011 01:22 AM
781/2fxs
May 13, 2009 11:24 PM
