Ape Handling
Old Aug 9, 2007 | 03:47 PM
Donlu30's Avatar
Donlu30
Default Ape Handling
Got an ape question. Just put 16"s on my fxd and the ride is great, until i hit about 70 or so miles and hour. At that point the bikes front end shakes tremendously and also around high speed turns. Is this a setup problem or just the way they handle?
Old Aug 9, 2007 | 04:04 PM
Cabo's Avatar
Cabo
Default RE: Ape Handling
With out a doubt a set up problem. How much bar movment do you have when sitting still? I just put 16's on mine last week and I put it through the paces on the way home. 60, 70 up to 80 mph. No vibration or wobble. I suspect your bushings need to be upgraded...check out this thread.....
https://www.hdforums.com/m_2032382/tm.htm
Strange Trip's Avatar
Strange Trip
I'm no bike mechanic, but my rider's instinct tells me that's not normal. You used the words "shakes termendously" and with that I'd have it test driven by someone with mechanical knowledge. Ride Safe - J
Old Aug 9, 2007 | 04:26 PM
dailydriver's Avatar
dailydriver
Did you change the stock riser bushings? If not is there alot of play in the bars back and forth?
Get some poly bushings (about $30) and should smooth things out...Hope this helps...Later
Old Aug 9, 2007 | 05:44 PM
thrillseeker's Avatar
thrillseeker
here is a conversation that has been going on for a few days now
https://www.hdforums.com/m_2020652/tm.htm
maybe something in here will help
Old Aug 10, 2007 | 05:27 AM
Donlu30's Avatar
Donlu30
Thanks thrillseeker. I think i will give those bushings a swap.....That thread just confirmed it....
Old Aug 10, 2007 | 06:47 AM
Donlu30's Avatar
Donlu30
Actually, thanks to all of you guys for your help!
trikky74
Mar 7, 2017 08:18 AM
D'R34P3R
Aug 29, 2015 09:43 PM
1sweetglide08
Sep 2, 2011 09:00 AM
SplinterMC
Feb 14, 2008 04:22 PM
