rear brake pedal not activating lights.
Old Dec 30, 2021 | 08:17 AM
TTR's Avatar
TTR
Default rear brake pedal not activating lights.
I have a 2010 Wide glide. The brake lights were working fine yesterday but today the rear brake pedal is not activating the brake lights. The front brake activates the brake lights fine. I guess the activation switch for the rear brakes went bad but where is it? Thanks
Old Dec 30, 2021 | 08:27 AM
Vonswanko's Avatar
Vonswanko
It’s a hydraulic switch/banjo bolt right off the rear master cylinder. Pretty simple swap.
you can test it by unplugging it and jumping the 2 terminals together. If it lights up, then it’s the switch.
Old Dec 30, 2021 | 08:31 AM
TTR's Avatar
TTR
Thank you, I'll take a look and get back to you. Thanks again..
Old Dec 30, 2021 | 09:23 AM
AirCav101's Avatar
AirCav101
I had always disabled mine... incase Johnny law was looking to see my admission of guilt.
Old Dec 30, 2021 | 07:47 PM
tenshots1's Avatar
tenshots1
Stage II
I just replaced one of these the other day ON MY 08 FXDF. Originally I ordered one off of amazon that people claimed fit the dyna, but it definitely did not fit. I ended up going with this one: https://www.denniskirk.com/drag-spec...rd/2101942.sku
Some people online say you can compress the brakes and not have to bleed them as a result. This definitely did not work for me. Brakes were spongy after I swapped the switch, so I bled them and now it works great.
Old Dec 31, 2021 | 11:33 AM
TTR's Avatar
TTR
Picked up the $11 pressure switch at the Harley dealer yesterday. Swapped it out just a few minutes ago and the rear brake lights work fine now. Thank you for your help Vonswanko.
Old Dec 31, 2021 | 11:58 AM
Vonswanko's Avatar
Vonswanko
Nice! Love it when a plan comes together!
Old Dec 31, 2021 | 07:24 PM
Bluesrider.df's Avatar
Bluesrider.df
I had to bleed my brakes after changing as well.
Old Jan 1, 2022 | 03:22 PM
John CC's Avatar
John CC
The trick is to carefully depress the pedal right before you put the new switch in, just enough so the fluid forms a meniscus at the top of the fitting. That way, when you introduce the new switch, there's no air trapped in the fitting. Depressing the pedal also blocks the fluid from returning to the reservoir, allowing air in.
on3wego
Oct 21, 2018 07:40 PM
Ranger12s
Shovelhead
Sep 30, 2017 08:27 PM
Hrlyrider
Dec 2, 2013 04:32 PM
TexFF
Jul 24, 2013 07:35 PM
Akkarine
Apr 2, 2012 11:08 AM
