Lighting Proof Of Concept
Old Jan 19, 2022 | 03:19 PM
Jay Guild's Avatar
Jay Guild
Originally Posted by Nemosengineer
I'm still waiting for electrical stuff to show up but I'm making progress on other fronts. My Performance machine rear caliper showed up along with a RSD rear master cylinder cover. I'm still waiting on the Trac Dynamics alloy swingarm to arrive fingers crossed.
Full Speed Ahead: Mike
Untitled by nemosengineer, on Flickr
Is there any way you could get me a measurement from axle hole to the top of the caliper body?
Old Jan 19, 2022 | 08:22 PM
Nemosengineer's Avatar
Nemosengineer
Hi Jay,
From axle center to the top of the caliper 6 1/4 inches, to the top of the banjo bolt just over 6 3/4 inches, to the top of the bleeder valve just over 7 1/8 inches. Always happy to help.
Have a great evening: Mike
Old Jan 25, 2022 | 09:58 AM
Jay Guild's Avatar
Jay Guild
Hi Jay,
Thanks for the measurements. I put on a smaller diameter rim a couple years back but I have to take the disk off to get the stock caliper off now. I'm hoping to find one that can slip between the disk and the rim.
Old Jan 25, 2022 | 12:26 PM
Bob_fxdb's Avatar
Bob_fxdb
Nice bike! Looking forward for your upgrades!
Many people upgrade their rear caliper but not their master cylinder. You won’t utilize the calipers potential. The problem is how bad the oem rear masters are with aftermarket calipers.
Old Jan 29, 2022 | 10:34 PM
Nemosengineer
Hi Bob,
Sorry I took so long to get back to you, work has been eating my brain and eating up some serious time. The main driver for the replacement of the caliper is unsprung weight and the somewhat wooden feel at the pedal, I hope this caliper fixes the situation. the PM caliper is sized to be compatible with the Dyna master cylinder The plan is to throw a fresh seal kit in the master when I pull the bike apart in a few weeks (I'm still enjoying the cool winter riding weather). I run Motul 600 fluid and change it when I feel guilty, about every 2 years, I like it because it doesn't turn into goo like the stock Harley fluid.
Best Wishes: Mike
No progress photos but a good friends retirement photo, I'm on the right.
Old Jan 30, 2022 | 07:19 PM
Nemosengineer
Something like progress... I pulled the switch pod apart and verified the contacts were within spec 0.2 to 0.3 ohms in both positions in all switch's so we are good there, broke out the wiring into switch sets and numbered the conductors, only two of the switch's are active (horn and passing lamps), the third will be powered and wye off the bundle and be terminated to be used for something later.
Both horns are here, a Denali Sound Bomb and a Lucas Altette that has a very nice note, a pod switch controls which horn is activated from the horn button. The Denali is powered by a 35 amp relay with a 30 amp fuse, the Lucas by the modified existing wiring. The passing lamps are on their own circuit with a 35 amp relay and 15 amp fuse.
Most of the wiring supplies are here, factory Deutsch connectors in regular and high amp versions, silicone insulated wire in 14 and 12 gauge, wiring conduit which was not easy to find (http://www.cycleterminal.com/sleeve-tubing.html), so we are almost ready to go.
: Mike
Old Feb 3, 2022 | 08:13 AM
eighteight's Avatar
eighteight
You do nice work
Old Feb 3, 2022 | 08:27 AM
Suede Blue Man's Avatar
Suede Blue Man
... I'm on the right.
Untitled by
Only D.B. Cooper could pull off hiding in plain site with a disguise like that, has an old northwesterner "way to go" D.B.!
Old Feb 3, 2022 | 10:14 PM
Nemosengineer
Really we are just a bunch of old pirates...
: Mike
Old Feb 4, 2022 | 07:42 PM
Suede Blue Man
No kidding, you guys are the folks who have gone down in those type of crafts, that must be quite exhilarating! Hats off to you
