Big Sucker
Old Aug 10, 2007 | 07:05 PM
Drexor69's Avatar
Drexor69
Default Big Sucker
What are the real differences between the AN Big Sucker Stage I and II?
From what little I've been able to find it looks to me like the BSII is just a little bit bigger. Is that the only difference?
What, if any, difference am I likely to see performance wise?
Thanks!
Old Aug 10, 2007 | 07:11 PM
Cornhusker's Avatar
Cornhusker
Default RE: Big Sucker
It'll pull more air. If you just do exhaust and air box, you definitely don't need it.
Old Aug 11, 2007 | 01:49 AM
Drexor69's Avatar
Drexor69
cool, thanks
Old Aug 11, 2007 | 11:38 AM
Dirtrace95's Avatar
Dirtrace95
The difference is the amount of filter area, Stage 2 has alot more. You'd have to use a round
filter cover from an EVO to use it. You can also buy a after market one also. The stage 2 flows considerably more air.
Old Aug 11, 2007 | 12:40 PM
Drexor69's Avatar
Drexor69
will it give me better performance in a Stage 1?
Old Aug 11, 2007 | 12:57 PM
tdshepard's Avatar
tdshepard
Unsubscribed From Forum
I think the big suckerII is only justified if you have bigbore cylinders, aftermarket cam, head work, etc. If you are just going to stick with an exhaust and air filter mod the big sucker I will be fine.......
Old Aug 11, 2007 | 01:38 PM
Dirtrace95's Avatar
Dirtrace95
The stage 1 will run just as good and the stage 2 unless your building a biggir engine and using a bigger throttle body.
Old Aug 11, 2007 | 06:50 PM
mentor70's Avatar
mentor70
I have the big sucker and it was restritive on my 95 in. I just bought the Zippers filter and that helped alot. its about 1 inch longer that the standard big sucker or stage II. I
If it had been available when I was looking the first time I would have bought it then!
I mean, You know your going to do somthing with your bike! so just get the biggist A/F you can find and buy it once!
papejr
2014-2024 Touring Models
27
Jan 6, 2016 02:00 PM
forrest42
Jul 19, 2011 09:10 AM
Micheletti
Oct 11, 2009 07:26 PM
Herr Monk
Nov 19, 2007 08:18 AM
Todd Vikan
Aug 12, 2006 04:20 PM
