FXD Front fork springs
Old Feb 7, 2022 | 11:05 AM
AftaDynaMint's Avatar
AftaDynaMint
Default FXD Front fork springs
Hi. I need to do my fork oil before spring so I was going to upgrade the springs in my 08 FXD 49mm forks. Anyone ever used Patriot genesis? https://www.speed-kingscycle.com/products/patriot-suspension-genesis-front-end-springs
These were recommended as the best bang for the buck by my local indy. Id never heard of them before. Only the typical brands (progressive, ohlins, legends, fox)
Any suggestions are welcome. I know good stuff isn't cheap, and cheap stuff isn't good but I'm looking for best bang for the buck.
Im 150lb rider. Riding is split between ripping up back roads/twisties and highway touring.
Thanks
Old Feb 7, 2022 | 12:09 PM
eighteight's Avatar
eighteight
As long as you`re price shopping
Racetech springs are less $
Old Feb 7, 2022 | 12:15 PM
AftaDynaMint
Have you ran Racetech? Any good?
Old Feb 7, 2022 | 12:18 PM
eighteight's Avatar
eighteight
I like them better than the Progressives that I removed, but to be fair I installed Ricor Intiminators at the same
( `99 RK not a dyna , so it`s easy to dial in using air pressure )
Old Feb 7, 2022 | 12:21 PM
AftaDynaMint
( `99 RK not a dyna )
Not sure what that is. Ill look into it. Thanks
Old Feb 7, 2022 | 03:45 PM
Danrides's Avatar
Danrides
I bought Progressives and instantly regretted it.
I've heard great things about Racetechs, Ohlins, Legends.
Old Feb 7, 2022 | 09:34 PM
sharkey's Avatar
sharkey
Have used Racetech’s in 3 different HD’s, an XLH and two Dynas. Have a set on the shelf for an XLCH build. They work well in our primitive front forks, along with the right oil. Can make a discernible difference
rauchman
May 5, 2016 10:15 AM
Redhill Phil
Sep 25, 2012 11:06 AM
jlilnc14
Aug 22, 2012 07:16 PM
hdpedro
Dec 15, 2010 09:51 AM
hogbag07
Jan 6, 2008 11:04 AM
