Dyna Cutting out
Old Mar 9, 2022 | 04:08 PM
Copa Mick's Avatar
Copa Mick
5th Gear
Was that wiring going into the Iac or on the backbone for the IAC ?
Old Mar 10, 2022 | 06:12 AM
Nitrochicken's Avatar
Nitrochicken
Sorry. Neck=Backbone.
Old Mar 10, 2022 | 10:41 AM
777's Avatar
777
If the lights are cutting off as well, check the ground wire where it connects to the engine. There may be another wire that splits off that and goes to the frame and cut the heat shrink to check the wires that go into that ring terminal. I had an issue on my 2009 where the copper stranding on the wire going to the frame broke at that spot and would cause very intermittent cut outs. The heat shrink was holding it most of the time just enough for it to work, but every once in a while engine and lights would all cut out and then come back on. I think I ordered a new cable but looking back I probably would have put a separate ring terminal on both wires and then connected them to the post/ground on the engine. Hope you get it figured out soon!
Old Mar 10, 2022 | 04:03 PM
Copa Mick's Avatar
Copa Mick
5th Gear
Yep agree, starting to look like the cable might be the issue even though it looks ok, I've got one on order already so we'll see, fingers crossed. Thanks for the info.
Old Mar 12, 2022 | 07:14 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Had the same situation on a Sportster with corrosion and broken cable under the heat shrink and find a spot on my 02 Dyna's battery to frame ground wire last year.
Old Mar 13, 2022 | 08:30 PM
Copa Mick's Avatar
Copa Mick
5th Gear
Thanks for that, got a new negative cable coming next week.
Old Mar 15, 2022 | 02:27 PM
seniorsuperglideE8
If my Km's to miles is right, that's 80,000 miles. Check in the DIY section for information on how to check the Crank position Sensor voltage. But, the problem is the CKP is notorius for dying at any time. Not that hard to change and relatively cheap. The CKP triggers the firing signal to the ECM, to the coil to the plugs.
Old Mar 15, 2022 | 03:37 PM
Copa Mick's Avatar
Copa Mick
5th Gear
Ok, another thing to check ! lol
Crittenden
Aug 6, 2021 02:11 PM
blueangel73
Forum Issues
Sep 5, 2018 04:07 PM
Catchufirst
Forum Issues
May 17, 2011 08:27 PM
