Dead 07 DWG
Old Aug 13, 2007 | 06:29 PM
UCONN_DWG's Avatar
UCONN_DWG
Default Dead 07 DWG
Got back from beach about 5 pm yesturday, washed bike down as usuall on Sundays, started fine and put backin garage till tomorrow. Last nite around 9 ish was in garage for a smoke and hear a noise coming from under the gas tank sound like the fan on my computer/humming noise. What the F, call wifey and kid cause I think I'm going nuts to see if they hear it, yup all agree there is a noise coming out from under the gas tank, shake the bike and set of the alarm and noise stops. Got a doc apointment and want to take the bike so I can use the commuter lane, its dead!! No electrical what so ever, main fuse is fine. HD is coming to get it tomorrow. Any ideals what happened, service manager had no ideal what was wrong when I told him.
Old Aug 13, 2007 | 06:39 PM
Ganooch's Avatar
Ganooch
Default RE: Dead 07 DWG
Did you check the battery connections? If you have taken them off recently it is likely that they are loose. Had this problem repeatedly with my WG and after cutting off the star washers on the bolts it has been fine. Worth checking out.
Old Aug 13, 2007 | 06:43 PM
UCONN_DWG's Avatar
UCONN_DWG
No, have not played with any of the elec., engine or exhast, just a lot of chrome.
Old Aug 13, 2007 | 09:03 PM
trip20's Avatar
trip20
...shake the bike and set of the alarm and noise stops.
You know that noise you initially hear when you flip the Run switch on? Was that the noise you heard up until you tripped the alarm?
Old Aug 14, 2007 | 01:43 AM
granpinto's Avatar
granpinto
2nd Gear
I also live on the beach and had to same problem...turned out it was the start relay in the fuse box...corroded teminals....I shipped it back to the dealer but he just cleaned the terminals and it runs fine now....need to get a waterproof fusebox from somehwere?
Old Aug 14, 2007 | 07:26 AM
UCONN_DWG's Avatar
UCONN_DWG
Check the battery cables, fuses ok, but inside of fuse box had water and rustin it, moisture all over the fuse box, can not quite describe sound but it did not sound like fuel pump. I'm starting to lean twords a defective alarm due to the noise stopping after it was activated. Thanx for your suggestions
Old Aug 14, 2007 | 08:35 AM
glebo's Avatar
glebo
sounds like the same thing that happened to me. It was a shorted ignition switch. Never woulda thought of that. I have a 06 superglide, luckily it was under warranty. good luck, I hate electrical problems.
Jorojin
Oct 12, 2015 01:54 PM
cike
Jun 15, 2011 02:55 AM
eddie31770
Aug 24, 2009 07:35 PM
1peter
Jun 5, 2009 11:10 PM
RMBLON
May 17, 2008 04:23 AM
