Is it just me?
Old May 22, 2022 | 04:47 PM
crzoomb's Avatar
crzoomb
Default Is it just me?
When I ride my bike just to cruise around it seems like everything is a bit more clunky and labored, like cruising at 2000-3500 RPM’s.
When I I do a more spirited run with friends and family and bang the gears around 3500-5000 everything seems to gel better.To me the bike seems like that’s the G spot.
I know these 222’s are supposed to be very low to mid cams, they seem like a perfect cam for a light Dyna
My 94 Gsxr 1100 will be gone soon
Old May 22, 2022 | 04:49 PM
SirHarley's Avatar
SirHarley
Cool
Sounds like you may need to have your primary adjusted, or your transmission serviced...
Old May 23, 2022 | 06:11 AM
crzoomb's Avatar
crzoomb
Time to break out the service manual
Old May 23, 2022 | 06:35 AM
Brando4905's Avatar
Brando4905
Don’t think it’s just you. My 96” is stock and I feel it’s happiest in the 3k to 4k rpm range.
Old May 23, 2022 | 09:12 AM
2500hdon37s's Avatar
2500hdon37s
The 222 cams are better for a heavier touring bike, or if you just like lower end power and tend to short shift. But they still make peak torque at 3700rpm.
It sounds like you’re lugging the bike a bit at 2000rpm, cruising I’m never below 2400, and usually 2600-3100. Below 2000 you can definitely be lugging the bike and you will hear clunking and get some jerkiness from the compensator loading and unloading from the power pulses of the engine. With only 2 cylinders firing the pulses aren’t near as smooth as you’d have with a big V8 that is happy from 1400-2500rpm while cruising. So the higher RPM really smooths the engine out.
Old May 23, 2022 | 11:23 AM
Max Headflow's Avatar
Max Headflow
Exhaust system and good tune make a big difference in how the bike runs at lower RPMs.
Old May 23, 2022 | 11:26 AM
smitty901's Avatar
smitty901
It is you. You just get a buzz cranking them RPMs
uwiik
Dec 23, 2018 07:30 AM
Tee Bagger
Sep 23, 2012 05:33 PM
FxstsTwo@yahoo.com
Jan 9, 2010 04:20 AM
Rhonda
Oct 3, 2009 01:36 PM
gata42
Oct 25, 2005 08:52 PM
