Radial Tire Question
Old Aug 15, 2007 | 07:55 AM
Patch's Avatar
Patch
Default Radial Tire Question
I have a 2005 FXDCI with HD mirrorstar wheels.
It's time for new tires, does anyone know if I can switch to radial tires???
Old Aug 15, 2007 | 09:19 AM
Trout's Avatar
Trout
Default RE: Radial Tire Question
Here's what Dunlop says (from their website):
Question: Can I change my tires from bias ply to radial or vice versa?
Answer: Bias and radial tires have significantly different dynamic properties. They deflect differently, create different cornering forces, have different damping characteristics, as well as other differences. In order for radial tires to be introduced into the two-wheel market, it was necessary to change certain characteristics of the motorcycle. The introduction of the radial tire led to such things as modified frames, new steering geometries and suspensions. Therefore, it is recommended that a motorcycle be used with the type of tire construction that it came with originally. If a change is to be made, then it should only be done if the motorcycle or tire manufacturer has approved the change. Above all, do not mix bias ply and radial tires on the same motorcycle unless it is with the approval of the motorcycle or tire manufacturer.
Old Aug 15, 2007 | 10:05 AM
xxxflhrci's Avatar
xxxflhrci
The wider tired Softails have a radial in the back and a bias in the front. I'd go for it.
rob0225
May 30, 2013 11:57 AM
gregmay
Jul 28, 2010 06:36 PM
Jim Dawson
Aug 19, 2009 10:07 PM
Mikeeeeeeeeee
Oct 2, 2007 07:41 PM
HDF Tech
Aug 7, 2005 04:06 PM
