Ignition Switch
Old Aug 15, 2007 | 11:35 AM
Luther OBanion's Avatar
Luther OBanion
Default Ignition Switch
I have a 06 Street Bob (Cobalt Blue), since getting it the ignition switch seems to not work right. The first problem was the forks would not lock. I used graffite to loosen it up. Told to by the stealer.Worked ok until a few days ago. Icheked it and the whole ignition was loose and about to come out of its housing. Getting it replaced by the stealer under warranty. Just wondering if anyone else has this problem.
Also put on a set of Rush Slip-ons about 1 month ago and the tech did not tighten good enough and they came loose and fell of the bike. He was fired and the stealer isreplacing them.
Old Aug 15, 2007 | 01:02 PM
bikerdog134's Avatar
bikerdog134
Default RE: Ignition Switch
lucky to get slip ons replaced same thing happened to me and i got noehere with the stealer. happy riding
Old Aug 15, 2007 | 04:50 PM
cardboard's Avatar
cardboard
Know its under warranty. Lube yer lock with a teflon lubricant. Its probaly out of alignment in the forks . I've heard about it but never had it happen. Git a penn lite and a small screw driver and look up into the space where the pin locks in the forks, you might have to move the pin over some with the screwdriver.
hollandhunter
Milwaukee Eight (M8)
May 22, 2019 01:44 PM
spencer
General Topics/Tech Tips
Mar 25, 2018 11:50 AM
emperor wurm
Apr 5, 2016 02:28 PM
carlosgtn
Apr 10, 2008 01:52 PM
jbriley3
Sep 3, 2005 02:55 PM
