Starting my 07 Street Bob
Old Jul 6, 2022 | 07:46 PM
Jaxon91's Avatar
Jaxon91
Stage I
Default Starting my 07 Street Bob
I was riding down the road and my bike cut off. I towed it home and took the battery out to get it tested. The battery is good. I turn the key and the lights come on. When I attempt to start the bike nothing happens. No sound at all. I have tried starting in neutral and 1st gear. I am unsure of what it could be at this point. Any thoughts?
Old Jul 6, 2022 | 08:47 PM
nevil's Avatar
nevil
Are you getting power to the starter? Check the battery cable connection at the ground post on top of the starter. It might be loose/dirty.
Old Jul 7, 2022 | 04:56 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Could be many things, bad switch or wiring in the bars, bad starter relay or solenoid.. If your going to wrench on your bike you should get a Factory Service Manual.. Or at least find a copy of the wiring schematic so you can trace down the problem.. Some where on the HD website you can put in your vin to download the schematic for your bike..
Old Jul 7, 2022 | 06:15 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
To find the wiring diagram on Harley Davidson Service Information Portal, I google search:
"2007 wiring diagram serviceinfo"
Old Jul 7, 2022 | 08:57 AM
pgrchaplain's Avatar
pgrchaplain
Is the Thumb Switch on?
Jim55
2018+ Softail Models
Feb 10, 2020 10:50 AM
gdillon86
Jun 9, 2013 01:28 PM
willyd465
May 21, 2012 01:32 AM
willyd465
May 15, 2012 12:28 PM
jlwhitt77
May 22, 2010 11:07 PM
