Stiff Throttle .
Old Jul 13, 2022 | 09:09 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Originally Posted by John CC
When I installed my Avon grips I used powered graphite on the throttle grip. I don't recall if that was Harley's or Avon's recommendation, but either way it won't attract grit.
Sounds good. What the engineers say use in lock cylinders. First time my grip was off, it appeared Harley used clear silicone grease. Graphite was on the throttle cable. Some form of liquid lubricant was on clutch cable.
I installed the SS cables from Harley. They both seemed to have same system.
Those original OEM cables are on the wall in a big clear plastic bag. Bottom of bag has a noticeable amount of lubricant that has drained out of clutch cable.
Old Jul 13, 2022 | 09:31 AM
snake_eyes's Avatar
snake_eyes
Originally Posted by RIPSAW
Think he was referring to the inside of the twist grip. Maybe not. And yes, like I said, Harley has a very light silicon grease in post 2 for throttle grip.
And yes, they say lube the cable. But if you leave the cable liner dry, it will require a lot less maintenance. Once lubricated, it's like dumping oil in a key hole. It gums it up. That liner doesn't need lubrication.
If it's tight, yes I would lube it. And only if it was tight or lubricated in the past. Most Harley OEM cables have that liner. The optional SS braided ones I have seen don't. Lot of variables going on.
Interesting how you offered no help but once the user said what helped and advertised his grips, you offered your troll post. Bye
Troll??? It's a joke man...sheesh. Life's too short to get your undies in a bunch over some humor. What are you, like 80 years old?
Grendel4
Jun 17, 2010 11:46 AM
fsubassoon
Dec 18, 2009 11:33 AM
hd0wner
Jan 20, 2009 09:30 AM
btefft
Aug 6, 2007 08:51 AM
bdavis
Apr 23, 2007 11:18 PM
