2007 FXDB fuel filter
Old Jul 25, 2022 | 04:27 PM
greg3131's Avatar
greg3131
Default 2007 FXDB fuel filter
I can’t find anything on You tube .
I would like to replace the fuel filter . Any help ?
2007 streetbob . Thank you
Old Jul 25, 2022 | 04:51 PM
Reindeer's Avatar
Reindeer
If you don't have a service manual, invest in one.
Fuel filter is inside the tank, remove the dash and the cover under the dash. Fuel filter is on the fuel pump assembly, which is on the left side of the tank. It's not a fun job, but doable with a little patience. When I replaced mine I also replaced all the plastic lines with Gates submersible fuel line.
Old Jul 27, 2022 | 09:58 AM
Bubba Zanetti's Avatar
Bubba Zanetti
IDK if the filter is the same as the ones on the Road Kings but I changed mine on a RK and it was a real PITA. There is an articulating arm that holds everything in place inside the tank. I had a hell of a time getting that thing out of the tank. Patience is definitely a virtue on this job.
Oh, and make sure you buy new screws to bolt everything back in, the ones that hold the gasket on are one time use.
greg3131
Jul 26, 2022 11:26 AM
redsox
General Topics/Tech Tips
Feb 11, 2017 12:10 PM
roofgunner
Oct 10, 2011 10:43 AM
roofgunner
Oct 10, 2011 10:35 AM
mpuggie2
Welcome Area Only
15
Sep 26, 2011 11:23 AM
