2003 FXDWG Electrical Issues
Old Aug 1, 2022 | 07:17 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
When you turn on the left turn signal, what do the turn signals do?
When you turn on the right turn signals, what do the turn signals do?
Forget about running lights, tail lights etc.
Old Aug 1, 2022 | 07:35 PM
KK560's Avatar
KK560
When I turn on the left signal, the front stays lit and the back does nothing.
When I turn on the right signal, both the front and back flash.
Old Aug 1, 2022 | 09:55 PM
Max Headflow's Avatar
Max Headflow
Sounds like the bulb in the rear is burned out.. Could simply be a bad wire or ground to the rear turn signal.
Old Aug 2, 2022 | 08:13 AM
KK560's Avatar
KK560
I know the bulb is good because it's new and I tested it on the other side.
Old Aug 2, 2022 | 08:25 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Unplug the connector from the TSSM, make sure none of the terminals in the connector housing are pushed out, the Violet wire is the left turn signal.
Old Aug 2, 2022 | 11:18 AM
KK560's Avatar
KK560
Thanks! I was reading about the tssm and am going to check it out. Is it located under the seat?
Old Aug 2, 2022 | 01:17 PM
Max Headflow
If the light in front is on and the back not, it has to be the wiring to the back turn signal. The wire that feeds the front should go to the back turn signal. The light doesn't flash due to the TSSM not seeing enough load.
Old Aug 2, 2022 | 02:24 PM
Dan89FLSTC's Avatar
Dan89FLSTC
OP:
Does the left front turn signal get brighter when the button is pushed?
Old Aug 2, 2022 | 10:07 PM
KK560's Avatar
KK560
OP:
Nope. Doesn't make any difference.
Old Aug 3, 2022 | 12:01 AM
Max Headflow
OP:
Good point.. OP can ignore what I said if it don't get brighter.
and this is not true.
​​​​​​​The left front turns on with the ignition.
