Harley Airhorn not working??
Old Aug 18, 2007 | 08:09 PM
itznin's Avatar
itznin
Default Harley Airhorn not working??
I had some work done to my bike and the guy who did the work claims the airhorn is installed correctly.... He also said he double checked the positive/ground connection and if it isn't powered it wouldn't be working at all (this is his words) His claim is that the actual horn is defective and the wiring/etc is correct....
The horn sounds like one of those party favors where you blow in it and it and it unrolls some paper and makesa sound....
The horn sounds the same with/without the air hose going to the compressor...
Any ideas on what I can check?
Old Aug 18, 2007 | 08:15 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: Harley Airhorn not working??
Switch the wires at the bottom of the horn compressor......
Just swap the yellow and black wires to the opposing posts....
Old Aug 19, 2007 | 12:04 AM
GaryInSanDiego's Avatar
GaryInSanDiego
I had the same problem when I installed mine. Sounded like an elephant passing gas. The connections to the horn weren't seated properly. I pressed them in really hard and it solved the problem. When I get some time, I'm going to replace the connectors with better quality ones without all the rubber to screw up the connections. You can tell if the horn is working by connecting a battery directly to the terminals, but make sure you're wearing hearing protection.
Gary
Old Aug 19, 2007 | 07:52 PM
itznin's Avatar
itznin
ORIGINAL: Shovelhead Bob
This did the trick! Thanks a lot! LOUD as hell!!
Do I HAVE to mount this air hose to it? It's loud without it and running this to under the seat is going to require me to remove the gas tank.... Let me know
Old Aug 19, 2007 | 08:11 PM
Shovelhead Bob
Route the air hose as neatly as possible.....
It will prevent any large FOD from being sucked into the compressor, and destroying what you have accomplished thus far...
The hose is routed so that nothing can impede the intake of air....
Old Aug 19, 2007 | 08:52 PM
itznin's Avatar
itznin
I gotcha, but really no where to put it aside from following the orignal wiring that goes under the seat, which means I need to lift the tank....
I will do this next weekend hopefully....
How about if I cut the hose and just stick it behind the airhorn? Not bending it but that saves me from running it all the way back... What do you think?
Old Aug 19, 2007 | 09:44 PM
Shovelhead Bob
Run it to under the seat....
The Cheesehead
Apr 28, 2015 07:19 PM
asahi1234
Jan 25, 2015 12:56 AM
brandss
Jun 14, 2012 10:13 PM
hoethree
Apr 19, 2012 08:50 PM
07JakeelwoodHD
Dec 28, 2011 06:14 PM
