Front brake caliper
Old Jan 18, 2023 | 01:08 PM
de ed's Avatar
de ed
Default Front brake caliper
Having to rebuild my 2005 Dyna FDXCI front brake caliper. But the PAD PIN bolts, which seem to be 1/4" 12 point screws, are difficult to get to. The normal socket doesn't fit in the space. Any ideas?
Old Jan 18, 2023 | 01:17 PM
Scudda's Avatar
Scudda
I bought a 12 point thin wall 1/4 socket from Amazon for this
Old Jan 18, 2023 | 02:27 PM
de ed's Avatar
de ed
By any chance do you have the SKU number for it. Can't find it in Amazon or HD or Loewes.
Old Jan 18, 2023 | 02:46 PM
Scudda's Avatar
Scudda
Old Jan 18, 2023 | 02:49 PM
de ed's Avatar
de ed
thanks
Old Jan 20, 2023 | 06:52 AM
jake24lt's Avatar
jake24lt
Put the socket in a drill, and put your bench grinder to good use.
Old Jan 21, 2023 | 03:08 AM
cutter4292's Avatar
cutter4292
Tractor supply has them.
Old Jan 21, 2023 | 09:24 PM
TexasScooterTrash's Avatar
TexasScooterTrash
That's a 10mm 12 point socket you need.
Old Jan 28, 2023 | 03:10 PM
de ed's Avatar
de ed
Default Double thread merged: Brake pad pins
I have a 2005 dyna fxdci that needs to have the front brake caliper rebuilt. However the pads are held in by two pins that apparently need 1/4 inch 12-point thin wall socket in order to get them out. My problem is finding a 1/4 inch 12-point thin wall socket. Nobody seems to have it (not home depot, lowes, amazon, ebay, northerntool etc). Any ideas where I can get one or what else I can use to get the bolt out?
Old Jan 28, 2023 | 03:17 PM
deadhawg's Avatar
deadhawg
Look for a Snap-On or Mac Tool truck at a shop or if you see one, follow it to his next stop, they will probably have one.
You can probably order one from Amazon, though you might have to buy a set.
