49mm Front Fork Question
Old Jan 21, 2023 | 09:28 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Work smart. Loosen the top caps before ya loosen up the triple tree clamp bolt. Springs fit flush with top of tubes. No a lot of effort to get the top caps back on.
Old Jan 21, 2023 | 09:44 PM
Two Lane Tramp's Avatar
Two Lane Tramp
Hmm, well it took two guys to get my top caps on. Pushing down the spacer is a bitch. I was afraid I was going to get it cross threaded. I did both my bikes at the same time just to get it over with. I like the heavy duty SE oil.
Old Jan 23, 2023 | 09:27 PM
Max Headflow's Avatar
Max Headflow
I don't know if these is enough meat to drill a drain plug in a fork lower but I'd prefer it over draining from the damper rod. The big issue is that HDs dumb a bunch of crap into the lower fork area. If you loosen the damper plug it can migrate between the bottoming cone and fork lower. When you tighten it back down, you'll distort the cone and move the damping rod off center. Then besides bushing wear, you have the damping tube wearing out the inside of the fork tube and the damper rod piston.
I really don't have any problem with the crud buildup in the lower tube as long as it's the parts are undisturbed.
Maybe add a top fill hole also..
hanny
Jan 9, 2014 12:29 PM
fenderzig
Oct 26, 2012 02:50 PM
cbo111
Mar 17, 2012 10:05 PM
jefnightrain
Feb 14, 2010 08:42 PM
BrentsterS
Aug 10, 2009 08:46 PM
