T-Max help
Old Aug 21, 2007 | 12:59 PM
  #51
cardboard's Avatar
cardboard
Default RE: T-Max help
Sorry dude ! I haven't even tried to look for it. I just heard when it was gonna be released.
There is a bootleg copy going around right now, everybody is waiting on the officail release. The new release is suppost to have data logging and a lot of other nice featchers with it.
Old Aug 21, 2007 | 04:55 PM
  #52
Jman67's Avatar
Jman67
Any updates? Did you notice the difference with the new software/firmware?
Old Aug 21, 2007 | 08:16 PM
  #53
Drexor69's Avatar
Drexor69
Only got to ride it a couple of miles today but it's definately better than it was before. It's going to take a little more time in the saddle to know for sure.
Thanks for the help!
Old Aug 21, 2007 | 08:25 PM
  #54
cardboard's Avatar
cardboard
Did you look at it hooked up to the computer and look at the Afr's .
Old Aug 21, 2007 | 09:08 PM
  #55
Drexor69's Avatar
Drexor69
No, I cleared the learned settings, loaded the new map, initiallized the module, and ran through the auto AIC per the installation instructions...
During the Auto AIC I watched the AFR a bit, is that what you're asking? I think anything else needs more running time...
Old Aug 21, 2007 | 09:12 PM
  #56
damadman's Avatar
damadman
I get a lot of decel pop from mine, also i get some back firein from the intake any one else get that problem??(actually its morelike ahickup) I think im gonna get me a thunderheader im sick of these samsons i think they are the root of my problems
Old Aug 21, 2007 | 09:13 PM
  #57
Drexor69's Avatar
Drexor69
Nothing through the carb here...
Old Aug 21, 2007 | 09:14 PM
  #58
cardboard's Avatar
cardboard
You can hook the TM up to the computer and monitor the Afr. they should go between 12.5 or so. If your afr's ain't doing nothin you ain't in closed loop or yer bike ain't in auto tune mode. You can check Afr's at idle.
Don't let yer heat temp git over 280 at idle.
Old Aug 21, 2007 | 09:18 PM
  #59
cardboard's Avatar
cardboard
If you ever want a really good pipe you might not like the look of a 2in1 pipe.,The D&D fat cats 2 in 1are performance pipes. They work well with the TM also.
Look at some of the big builders like Ness and AIM, look at the 2in 1 pipe. After you've had them for a while they will grow on you.
Old Sep 12, 2007 | 10:08 PM
  #60
ubreal's Avatar
ubreal
I install my tmax with auto tune today to my surprise every thing seem to work fine very little popping and no pinging, even the green 6 speed light. I watch the afr readings they were at 12.5 +- .6 I through that it would be higher at idle like in the 13.8 like the map says it should be, may be it because the bike was not warm up yet. I look at the basic settings and the last row said need firmware 4.5.
