Need some help with 1995 Wide Glide resurrection
Old Jun 23, 2023 | 03:25 PM
  #41
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You need to replace both trap door bearings at the very least.
The gearshafts will come out attached to the trapdoor.
Remember, untorque the bearing nuts on the trapdoor before removing the gearset, it is much easier that way.
Old Jun 23, 2023 | 03:29 PM
  #42
Max Headflow's Avatar
Max Headflow
If it was indeed the water in the tranny that killed the trap door bearing, you probably have to replace the main drive gear bearing.. Inspect while you take things apart.
Old Jun 23, 2023 | 03:34 PM
  #43
Dan89FLSTC's Avatar
Dan89FLSTC
If it were my transmission that was waterlogged, I would replace all the bearings...
Old Jun 29, 2023 | 09:26 PM
  #44
AndyinCT's Avatar
AndyinCT
All done
So I know I probably SHOULD have taken the transmission main shafts out and tested and inspected everything, but I didn't. I got a slick puller for the side door on ebay and it worked like a charm. Knocked the bearings out and replaced them and pressed the side door back on. I didn't even need to remove any primary pieces, just the exhaust. Flushed the trans a few times and it's quiet and smooth again. Man, this motor is a gem.
Now, onto the dumpster fire that is the electrical system...
Old Jul 16, 2023 | 12:19 PM
  #45
AndyinCT's Avatar
AndyinCT
Well I'm finally getting around to the brake light not working and I need some help. This bike has an aftermarket brake light assembly and it only has 2 wires going to it. Under the fender I found 3 (presumably for the stock tailight) and the orange and yellow wire is capped off. In my manual I believe I found that wire to be for the front brake switch. Any ideas?
Dynamike95
General Topics/Tech Tips
Jun 18, 2021 07:36 AM
Schoolies
EVO
14
Feb 10, 2021 04:42 PM
nikman
May 24, 2019 12:53 PM
Slowmo
Jan 6, 2014 05:14 PM
23beatle
Apr 12, 2012 04:07 PM
