My 2016 fxdb when I am cruising in 4th gear or higher and I crank the throttle it fells like the clutch is pulled in half way for a second or two and then it starts pulling and my gear indicator will fluctuate down a gear has anybody had this problem before?
clutch is not slipping first second third it does fine only when I crank it in fourth or higher
That the first signs of a clutch slipping. In higher gears there is more load on the clutch making it easier to slip. and finally it grabs.
if readjusting your clutch doesn't solve the problem, its time for a new one. Your mileage especially with stock power does seem a bit low to need a clutch, might just be your driving style though.
