Checking the brake master cylinder function
Old Jul 19, 2023 | 04:58 PM
tj96's Avatar
tj96
1st Gear
Default Checking the brake master cylinder function
I have a 96 Dyna Super Glide. The service manual says to check the front brake master cylinder function with the cover off the master cylinder and: "Actuate the brake lever. Check to be sure there is a small spurt of fluid breaking the fluid surface when actuating the brake lever." Does this only apply to the front master cylinder? The front and rear master cylinders are different. How do you check proper operation of the rear master cylinder? Any help would be greatly appreciated. Thank You!
Old Jul 19, 2023 | 07:43 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Brake Check Procedure - Choose a street with no traffic. Accelerate to 35 mph. Hit front brake and come to a stop. Works? Repeat with rear. Works? If yes to both, your brakes are working.
Old Jul 20, 2023 | 11:32 AM
nevil's Avatar
nevil
Before you do anything, if the brake fluid is more than 2 years old it should be changed.
Old Jul 20, 2023 | 12:15 PM
jake24lt's Avatar
jake24lt
If his bike uses dot 5, it is not hygroscopic like dot 3-4
tj96
Jul 25, 2023 07:38 PM
buyarbi
Shovelhead
May 26, 2022 06:28 PM
Snoop417
Aug 30, 2021 12:35 PM
cirhere2
Nov 21, 2009 06:26 PM
whatzleft
Feb 20, 2008 03:26 AM
