How do tell if a motor mount is bad?
Old Aug 24, 2007 | 12:39 PM
grueter's Avatar
grueter
Default How do tell if a motor mount is bad?
Can someone tell me how tocheck if the motor mountare bad? I looked in the service manual and could not find anything on how to ckeck if they are bad.The only thingI can think of is to put a jack under the engine and put a little preasure on the engine is there a better way? Also when doing a engine alignment do you loosen the2 front and 2 side bolts on each mount or just the 2 center bolts on the front. and rear? 2006 Wide Glide with V/H big radius,PC111 and Big sucker AC.
Old Aug 24, 2007 | 12:53 PM
glebo's Avatar
glebo
Default RE: How do tell if a motor mount is bad?
Can't help ya with the aligning thing. But I suppose a way to check the motor mount would be to put the bike in gear, lock both brakes and slip the clutch out observing any excessive moving of the motor. This may take two people, one to do the operating and one to observe. Listen for clunking or excessive motor movement, that would be my guess.
I'm sure more people will have some good ideas.
Old Aug 24, 2007 | 06:55 PM
pauletich's Avatar
pauletich
excessive vibration is a good sign if you have bad mounts.
Jackpoticorn
Aug 25, 2014 02:46 PM
shortride
Oct 16, 2011 07:47 PM
Buzzardbait
Jul 3, 2009 05:01 PM
stng_96
Sep 2, 2008 12:22 PM
hdparrothead60
Jun 24, 2008 11:45 AM
