I need to help a friend replace front motor mount
Old Oct 16, 2011 | 12:57 PM
shortride's Avatar
shortride
Default I need to help a friend replace front motor mount
My friend has a 2007 Street Glide with an engine that bounces around like it's trying to come out of the frame. The rear cylinder exhaust bracket and header pipe is broken so we figure the front motor mount is shot. There is about 1/2" space between the washer and the bottom of the rubber.
Will someone please give me a basic run-down on the correct procedure for removing and replacing the front motor mount?
Thanks,
Old Oct 16, 2011 | 01:19 PM
mkguitar's Avatar
mkguitar
only done my evos,
leave all other mounting points as is, slide out the old mount, put in the new mount, check positioning, torque mount bolt to spec.
not much help, I know- got the manual?
Mike
Old Oct 16, 2011 | 02:37 PM
Lowcountry Joe's Avatar
Lowcountry Joe
You can search on this forum or you can get a manual. Or both. Everyone should have a service manual. Period.
Old Oct 16, 2011 | 02:54 PM
TunAfish's Avatar
TunAfish
4th Gear
If I might chime in here. I would replace at least both fronts to even the field and all if the wallet has the girth. Replacing one will most likely result in big vibes.
Replace what needs replacing > loosen all mount fasteners to just under snug > start > 1st gear roll out soft up the block a bit, turn around, and shift to 2nd ease the clutch in and roll stop the bike with the motor off > torque all fasteners to specs. This procedure will self center the motor and result in the least amount of engine vibration.
Or do what the next guy suggests... hahaha!
Old Oct 16, 2011 | 05:28 PM
Theakerr's Avatar
Theakerr
Do a search. I seem to remember that someone posted a load of pictures. Also, at least one supplier has/had a video showing how to do it.
Old Oct 16, 2011 | 05:32 PM
dawg's Avatar
dawg
http://www.glide-pro.com/install/ Go here and scroll down to the second video (motor mount install)
Old Oct 16, 2011 | 06:12 PM
flhtupser's Avatar
flhtupser
Ditto! That will walk you through it step by step. It's easy.
Old Oct 16, 2011 | 06:20 PM
Stiggy's Avatar
Stiggy
There is only 1 front motor mount on a 2007 I believe. It's the one you've already found.
If the plate attached to the motor is not touching the rubber, ( you can see the sleeve supporting it,) the mount is still probably good, When it touches the rubber, it has failed.
Torque the center nut 15 to 20 lbs.
Old Oct 16, 2011 | 06:54 PM
shortride's Avatar
shortride
Thanks dawg for the video. That was very helpful.
Old Oct 16, 2011 | 07:47 PM
run1fsr's Avatar
run1fsr
FYI - My 2003 service manual does not reference replacement of the motor mount. I figured it out by searching this site for past posts. Not that difficult to do.
fshaw
EVO
30
Sep 21, 2018 08:14 PM
McMurphy
Jul 24, 2013 08:23 AM
XMA
Nov 3, 2011 01:33 PM
crazytourglide
Jun 13, 2010 01:54 PM
jus2anoyu
Nov 26, 2008 01:23 PM
