Engine mounts/ isolators, is there really a difference vs. Cost ?
Old Sep 7, 2023 | 01:46 PM
snake_eyes's Avatar
snake_eyes
Originally Posted by jake24lt
Did you mean Max Headflow? or--------
I love that show and really, really miss the 80's!
Old Sep 16, 2023 | 10:32 AM
KentuckyChristian's Avatar
KentuckyChristian
Installed a Drag Specialties front mount, Kinetic Structures rear.
Front mount was trashed, rear, not so bad.
But figured that since I was into it, I might as well replace both.
I kept the OEM rear as a spare , just in case".
Front
Front
Front
Old Sep 30, 2023 | 10:50 AM
KentuckyChristian
Default Update.......
Replaced both front and back mounts.
Drag Specialties front, Kinetic Structures on the back.
The initial ride was as rough as a Cobb, except for a sweet spot at around 2,500 - 3,000 RPM where it smoothed out very well.
Each subsequent ride seems to break in a little bit at a time.
Even with solid riser bushings, there's little to no perceptible vibration at 3,000 rpm, where most of my riding takes place.
Old Dec 17, 2024 | 01:40 AM
Iwantithm's Avatar
Iwantithm
Stage I
I've worked on a few cars where the engine mounts were definitely a game changer. A couple of years ago, I swapped in some higher-end NVH isolators for my car. I wasn't sure it was worth the extra cost, but after driving it for a few weeks, the difference was clear. The ride was so much smoother, and the engine noise was significantly quieter, even at higher speeds. It was a huge upgrade in comfort. Honestly, for me, the investment paid off. If you're sensitive to vibrations or engine noise, a quality isolator really makes a noticeable difference.
Old Dec 17, 2024 | 02:59 AM
OakMountainRider's Avatar
OakMountainRider
Hello, my front motor mount collapsed a few years ago. I replaced it with Drag, but it gave me vibrations. So then I replaced the Drag with Predator. I still have vibrations around 2.500 rpm, but it’s better than Drag. Also, on the plus side is the h a n d l i n g. With Predator the bike is steady as a rock when you twist the throttle out of a bend. With Drag and stock you avoid that, because you lose balance. At least this has been my experience.
I have read about this phenomenon. It is called the Dyna Wobble. Predator takes you away from it.
KentuckyChristian
Carburetor Related
Jun 18, 2023 07:31 AM
James Rook
EVO
Apr 6, 2023 05:59 PM
215sporty
Feb 17, 2021 02:55 PM
2006FLST
EVO
31
Jun 18, 2011 10:53 PM
99Sportster
Jul 1, 2009 06:20 PM
