need to get a technical spec on an Metzler me 888.
the Tyre is an 200/50-18.
I would like to find the overall Hight in mm and inches as I've got a custom rear fender on my bike and need this spec for a possible project.
I've tried Metzler's website but won't let me download the tech specs for some reason.
Thats a tire size calculator, all based on the theoretical size. With different molds, different wheel widths, and inflation pressures will play into the actual inflated dimensions. Most, if not all 200/50 R18's aren't going to measure 25.8" once inflated.
Although for the purpose of the OP 26.25" would probably be a safe bet to run with.
Is that a guesstimate or do you have the actual tire and rim combo as recommended for the tire??
