Not starting dyna);
Old Feb 1, 2024 | 11:57 AM
BmcYaya's Avatar
BmcYaya
Stage III
Default Not starting dyna);
Installed RG 103 in 08 dyna FXD Frame so ran acr off empty spare fuses in fuse box ran off fuel pump but everything seems to be fine fuel pump is priming good can hear acrs going off *** well but bike isn’t starting just cranking has spark getting fuel just isn’t cranking over can acrs be reason also have stock starter if that has anything to do with it
Old Feb 1, 2024 | 06:24 PM
Rounders's Avatar
Rounders
Unplug ACRs and see if it starts.
I don't know much about them, but doesn't something have to tell them to operate? Did you wire in a button?
Old Feb 2, 2024 | 10:25 AM
hattitude's Avatar
hattitude
Just a guess here, but....
Are you using the 2008 OEM ECM?
I don't remember when the OEM ACRs came out, but I thought it was in 2010. Your 2008 OEM ECM may not be compatible with the ACRs.
Do you have a tuner? Did you download a tune for the new engine?
If you downloaded a tune with the ACRs enabled, or you simply wired them to activate upon start up, and your ECM doesn't recognize the ACRs, that could be your problem...
As Rounders suggests, unplug the ACRs and see if it starts...
Old Feb 3, 2024 | 05:41 PM
Max Headflow's Avatar
Max Headflow
Plug wires swapped. How do you know it's getting fuel? Plugs wet?
Old Feb 3, 2024 | 07:33 PM
Harley_ish's Avatar
Harley_ish
Originally Posted by BmcYaya
... bike isn’t starting just cranking has spark getting fuel just isn’t cranking over ...
Well, which is it?
Old Feb 3, 2024 | 07:37 PM
paulmedford's Avatar
paulmedford
its cranking over or not? If you unplug the acr it won't release compression, is it that the bike is not turning over health or turning over health but not starting? send a video if you can
Old Feb 3, 2024 | 08:09 PM
John CC's Avatar
John CC
My favorite customer oxymoron: "It cranks but it won't turn over"...
There doesn't seem to be a universal understanding of crank, turn over, crank over and start. When someone says two of them in a row, like "cranks but won't crank over" it usually means it will turn over but it won't start. (If you know what I mean...)
Boyfriends dyna won't start...$.O.$
Nov 13, 2022 11:16 PM
pab3rd
General Topics/Tech Tips
Apr 6, 2021 01:27 PM
Tyroidll
Feb 9, 2014 12:11 PM
Bradley Jones
13
Jan 15, 2009 08:04 PM
Bradley Jones
Exhaust System Topics
Mar 29, 2008 11:45 AM
