TC88 Engine Rattle
Old Apr 18, 2024 | 05:08 PM
  #51
Rounders's Avatar
Rounders
I would just set the wrench to spec. There may be some to tight. I am not not sure I would bother loosening them or not. MIght good experience from him to see if he over tightened or not,
Old Apr 18, 2024 | 08:25 PM
  #52
John CC's Avatar
John CC
It always takes more torque to break a fastener loose especially after it's had time to "age", than it took to put it there in the first place. If your desired torque is, e.g. 20 ft-lbs and you torqued them all to 15, they'd probably all click without moving, but they'd all be too loose. OTOH, if you had torqued them all to 25, then setting the torque wrench to 20 will only tell you it takes more than 20 to break them lose. Either way they're all wrong. Loosening them half a turn gives you a second chance to come up on the right torque.
Michael Rogers
Jun 21, 2021 09:18 AM
strych9
Milwaukee Eight (M8)
Jul 6, 2020 08:19 PM
LowriderPA
2014-2024 Touring Models
Jan 27, 2017 08:41 PM
The Cheesehead
Apr 7, 2015 06:46 PM
