oil leak 07 FXDC
Old Apr 22, 2024 | 10:24 AM
WS6 Formula's Avatar
WS6 Formula
Originally Posted by Geralda321
Hello all, i just found an oil leak on the rear cylinder at the back, looks like its coming from the cover/cylinder joint . My bike is a 07 only has 16K miles on it its barely broken in. is this a known issue ?
Im hoping its possible too just tighten the cover bolts down , or should i take cover off and check head bolts?
any suggestions?
Rocker Box Oil Leak
https://www.hdforums.com/forum/dyna-...-oil-leak.html
Old Apr 22, 2024 | 05:00 PM
Rounders's Avatar
Rounders
Since you got it that far, might as well do breather. My 07, one fell aprart. Now that may be more mileage I don't know. Time plays a factor too.
I installed a quick disconnect for the cross over fuel line on mine. Draining gas and pull that hoses is one of the biggest PIA. Next time will be easier.
Old Apr 24, 2024 | 07:41 AM
Crazy's Avatar
Crazy
Which quick disconnect did you use?
Old Apr 24, 2024 | 08:51 AM
paulmedford's Avatar
paulmedford
hi ok heres some pics. ssee oil on fins cant quite tell if its from cover or heads ill investigate later when i can and post update
its the rocker cover gaskets, shange all, its a piece of work, bud doable. But really a common enough issue, dont stress over it. Its not that bad
Old Apr 24, 2024 | 09:08 AM
djl's Avatar
djl
Rocker housing leak; not rocker cover. More work but easy fix; replace with OEM gasket. Take a picture before removing gasket; easy to install wrong way.
Old Apr 24, 2024 | 10:56 AM
Geralda321's Avatar
Geralda321
6th Gear
hello everyone , thanks for the replies, sorry for the delay in getting back too you ive been working a LOT lately lots of guys calling out and well i have too do their job for them.
Anyway thabks again i will clean the oil off ride it and see what happens is there a chance the cover bolts worked loose and just need tightening? that would be nice .
If not i guess ill be pulling the top apart , (yippie) but it doesnt sound too difficult , i'm mechanically inclined thankfully and should be able too handle things.
i'll keep you all updated.
Thanks
Old Apr 24, 2024 | 12:19 PM
Bubba Zanetti's Avatar
Bubba Zanetti
Thanks
You could try to tighten them down but if it were me I'd make sure to use a torque wrench and the proper torque.
Old Apr 24, 2024 | 06:20 PM
Rounders's Avatar
Rounders
I got two different one off ebay, One came with a fitting to plug into the disconnect to drain it. Though I never used it.
Powermankw
Engine Mechanical Topics
Apr 6, 2024 03:47 PM
JHummel89
Nov 2, 2011 04:08 PM
brock161
Exhaust System Topics
Oct 3, 2009 11:18 AM
Shred4204
Sep 7, 2007 06:14 PM
parakiller
Aug 9, 2007 09:39 AM
