05 Dyna no power at switch or speedo
Old May 31, 2024 | 05:21 AM
Cwdyna's Avatar
Cwdyna
Stage IV
Default 05 Dyna no power at switch or speedo
Changed my switch blocks over all was working fine including starting the bike , next morning I have no power at right switches or my speedo won’t light up or show ks have I broken a wire somewhere when doing it up it was pinched at one point ? I see on other post it says maybe earth wire too speedo is off ? Please help
Old May 31, 2024 | 06:08 AM
user 7209823083's Avatar
user 7209823083
Maybe a stupid question, but have you checked the fuse?
Old May 31, 2024 | 06:51 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I had a '99 Sportster that had the same symptoms you are describing. I found the ground cable to the frame, pulled it and the terminal practically fell off in my hand . The strands that made the cable were corroded under the insulation and made a ground with one or two strands. Check those ground cables at both ends. Replace if there is corrosion.
Old Jun 6, 2024 | 10:24 AM
Bubba Zanetti's Avatar
Bubba Zanetti
I had the same happen on my 02 Super Glide.
jim70
Electrical/Lighting/Alarm
Dec 28, 2016 04:13 AM
jim70
Oct 4, 2016 07:16 AM
Roni
Oct 2, 2012 05:50 PM
bh76
Aug 20, 2012 04:20 AM
JustDave71
Feb 21, 2010 04:43 PM
