Dyna wobble at high speeds. Again.
first good hard ride at around seventy five and rolling on the throttle hard, felt like a Fu$&# hinge under my ***.
Contributed it to dried out motor mounts and when I checked the alignment it was way off sitting at 79 degrees.
installed glide pro motor mounts front and rear, ordered much heavier durability since my plans involved building horsepower in the future!
Installed and set the alignment to 90 degrees cant get more perfect then that, the first few rides felt like my 65 XLCH Shovelster! Shook me hard, they require break-in, gone as quick as the 96 huffed and puffed 110mph and solid and confident.
next was a full S&S 106 engine build from flywheels to cylinder heads, and in all honesty out on the road no issues from 10-130mph solid, except we did notice during other tuning on the Dyno, the rear of the drivetrain was crabbing under wide open acceleration.
Next was Spute posi for front and rear, it instantly converted it into a Hybrid smooth solid mount frame engine feeling with quicker steering reactions and no wobbling or fear of it!
Since then almost every drivetrain part has been changed due to not being able to handle the extra power, Baker grudge box, full Evo clutch and 30 tooth comp elimination set up, ceramic wheel bearings, C&S swing arm, quick shifter, chain conversion, 20 shot of happy gas!
What learned from this experience, Dyna could have been better except they left off the parts that made the FXR great!
Air cooled Harleys get ingrained into your soul, yes I owned faster Sport bikes and still do, but building this has had its share of frustration, pain, large - debt!
But no matter what its the most fun I have ever built, everything except tuning was me and JIMs tools & Harbor freights 20 ton press.
its like a two wheel 60s big block muscle car, turns like ****, stopping requires advanced thought processes, but light to light its all tire smoke hard acceleration and laughter!
loving every moment!
my apologies got side tracked
1-good quality mounts
2-proper alignment
3-for true confidence Spute
hope this helps
Jeff
@Max Headflow You are saying that the outer race of the first installed bearing is fully seated into the hub. When you install the second bearing, the outer race is XX" amount away from being fully seated in the hub????? Only the inner race of the second bearing is fully seated against the spacer??? Only a press fit is what keeps the hub from sliding side to side on the bearings??
I am used to setting up tapered wheel bearings. If you don't shim the spacer properly and leave it too loose, the wheel will move side to side as well as wobble.
Thank you!
Tom
Thank you!
Tom
Whatever you press the second bearing in with needs to be flat between the inner and outer race so the bearing spaces off the center spacer..
The important thing is that there are many wheel bearing tools are not machined to do so..
The whole idea is to reduce assembly time.. Timkens need to be set up.
That is the way it has been done on metric bikes and all types of machinery for eons....
