Computer shutting down running lights?
Old Aug 7, 2024 | 01:16 PM
Hoges's Avatar
Hoges
Originally Posted by 5gear
Nice work sorting that out. I haven't noticed a check engine light, so i didn't think to look for codes, but i suppose it couldn't hurt to check.
The engine check light didn’t come on when I had the issue with the neutral switch wiring, but the fault code was there.
Old Aug 12, 2024 | 11:12 AM
5gear's Avatar
5gear
Just want to say thanks for your reply, just like you mentioned, there were a few codes logged and it looks like I have a short somewhere in the lights. I started looking into it, moving wires around, and the lights have not gone off since. Hopefully I will be able to find and fix the actual problem next time I work on it.
Looks like my pessimism got the best of me this time, but thankfully I came on here before I overreacted.
Old Aug 12, 2024 | 04:50 PM
Hoges's Avatar
Hoges
Glad you now have some direction to look for.
I would check the wiring from the bars where it goes in to the head stock, mine is like a rats nest of wiring and connectors shoved in there, it would not take much for a wire to rub through and cause a intermittent short.
Looks like maybe its only a ECM fault that will have the engine check light come on and not with a BCM related fault.
Old Aug 12, 2024 | 05:02 PM
TriGeezer's Avatar
TriGeezer
My guess is that the computer thinks the voltage is low and is shutting down less important draws. Headlight, brake and turn signals never shut down.
It doesn’t do that.
Rmichmer
Jul 29, 2025 10:11 PM
DarthJohn
Feb 5, 2024 10:28 PM
MooseBAB
Electrical/Lighting/Alarm
Oct 19, 2020 03:10 AM
Tomas377
Oct 21, 2014 04:52 AM
billjoat
Jan 20, 2013 09:06 AM
