Tank swap Questions
Old Nov 22, 2005 | 10:45 AM
intruder400ex's Avatar
intruder400ex
Default Tank swap Questions
I would like to switch my tank on a 04 fxd/I with a split tank either WG or Lowrider to move speedo on tank is this a straight forward swap or is it going to need some modifications?
steve
Old Nov 22, 2005 | 05:53 PM
traveler's Avatar
traveler
Default RE: Tank swap Questions
Fuel injected bikes, at least the Dyna's have the fuel pump for the fuel injection inside the tank. To do this, you will have to use a split tank with the fuel pump inside, like a tank off of a Feulie softtail, etc. This is an expensive thing to do! I wish I could put a peanut tank on mine, but I have the same problem.....and i don't want to give up the fuel range either, I guess...
joe
Old Nov 22, 2005 | 07:04 PM
RonnieJ's Avatar
RonnieJ
tank off a FI lowrider or wide glide should bolt on I would think. You'll have to move and or splice some wires but you knew that.
bigmack
Mar 23, 2020 12:18 PM
TLD
Harley-Davidson Street
Apr 5, 2017 05:55 PM
baldric
Sep 29, 2015 04:13 PM
RJC
Powdercoat & Paint
Jul 26, 2011 05:29 PM
friknjok
Exhaust System Topics
Feb 12, 2008 09:05 PM
