spitting and sputtering under load
Old Aug 28, 2024 | 08:09 PM
DeeRoe's Avatar
DeeRoe
Keep it simple….drain the gas out…..swish in a little SeaFoam…..get fresh gas from a different station…..try it again
Old Aug 28, 2024 | 08:21 PM
Max Headflow's Avatar
Max Headflow
Have you checked the ignition timing?
Old Aug 28, 2024 | 08:31 PM
Max Headflow
Originally Posted by TFrame07
yea i wish it was. since then i have ripped every stock wire out of the bike and rewired it all. so i know that all of the wires are good. now im changing to different jets in the carb seeing if it gets better or worse. and no luck right now.
Including the grounds?
Old Aug 30, 2024 | 12:42 PM
TFrame07's Avatar
TFrame07
yes ignition timing is set properly. have checked it multiple times. and all ground cables are brand new.
Old Aug 30, 2024 | 12:43 PM
TFrame07's Avatar
TFrame07
Have you tried unplugging the stator?
i have not tried to run it without stator yet. I will give that a try.
Old Aug 30, 2024 | 03:24 PM
TFrame07's Avatar
TFrame07
Spoke with S&S today about carb tuning and it totally crossed my mind to change out the main jet air bleed. The new carb comes stock with a 40 jet in it. he told me to change it to a 60 jet. so im waiting for a 60 jet to come in the mail and will update yall on that. appreciate all the help and concerns on it.
Thank You.
Old Aug 30, 2024 | 05:26 PM
TFrame07's Avatar
TFrame07
well i couldnt wait for the .060 jet to arrive so i just threw a .072 in it to see if that was the problem and runs 100 times better. will be waiting to get the .060 jet in before i start the tuning process all over again. thanks for the help everyone.
Old Aug 31, 2024 | 04:15 AM
paulmedford's Avatar
paulmedford
thanks for the feed back
Old Aug 31, 2024 | 07:48 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I went back and reread, did these problems started after you put the G on it or was it with the E that came with the motor?
And what was your jettting with the E and what is your jetting with the G?
Old Aug 31, 2024 | 08:27 AM
Max Headflow
That's an interesting fix considering that the bike ran fine then all of a sudden started missing..
