Compensator problem
Old Sep 30, 2024 | 02:57 AM
SHVED's Avatar
SHVED
Default Compensator problem
Hi all! My bike is Dyna Fat Bob FXDF 08 TC 96.
Spoiler
I've recently started noticing that the motorcycle sometimes has trouble starting, and it's happening more and more frequently with each day. It feels like the engine cranks very unevenly, and there's also a strange noise when the engine stops. I removed the primary cover and completely disassembled the compensator, everything seems fine, except that the slider (12) is not pressed very tightly against the sprocket (11). I can rotate it about 1/2 inch back and forth without much effort. If I understand correctly, the spring inside the stator has weakened. I couldn’t find the PN for the spring, probably because it’s sold together with the stator, which is very expensive, especially since the stator works fine. Are there any other solutions or aftermarket options? Thanks for help!
Old Sep 30, 2024 | 04:51 AM
misfitJason's Avatar
misfitJason
Upgrade it to the newer style Screamin Eagle compensator. It requires the updated rotor
Old Sep 30, 2024 | 08:58 AM
Rusty Springs's Avatar
Rusty Springs
X2. The kit comes with a rotor.
Old Feb 17, 2025 | 01:58 PM
2007 Wide Glide's Avatar
2007 Wide Glide
Mine was knocking on start ups and would knock while riding when it was hot outside. I put the upgraded SE compensator on it and it works fine now. The upgraded one has bigger spring washers and can handle the torque
flhf150
Sep 1, 2024 07:01 PM
Dieselsoftail
27
Jun 5, 2019 01:14 PM
Limeygit14
Mar 6, 2017 01:51 PM
Millhouse 1340
EVO
38
Aug 24, 2013 02:47 PM
Traceman
Mar 26, 2011 07:09 PM
