Hyper flash issue
Old Oct 26, 2024 | 03:34 AM
ceffet's Avatar
ceffet
Stage I
Default Hyper flash issue
I have led lights with a load equalizer that fixed the hyper flash. I then bought the converter to connect brake and turn signal lights together and the hyper flash came back? The service engine light is coming on, should I worry about it? Has anyone had this issue.
Thanks
Old Oct 26, 2024 | 07:04 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Try removing the first equalizer.
I think there’s an equalizer in the converters too so you’re essentially running two equalizers.
Old Oct 26, 2024 | 07:35 AM
RANGER73's Avatar
RANGER73
Depending on who's converter you used, it may or may not have a built in LE.
If it has a LE built in, it could be bad, it happens.
Did you remove the old LE as I suspect you did? If so, put it back in.
What year bike?
Old Oct 27, 2024 | 12:36 PM
hattitude's Avatar
hattitude
Which run/turn/brake module (converter) did you buy?
Is your converter one module that does both jobs?
If the new R/T/B module (converter) both changes rear turn signals to Run/Turn/Brake and has a load equalizer built in, then take off the first, stand a lone, load equalizer.
If using two different modules, one for R/T/B only and another one for load equalizer, they have to be installed between the main harness and the rear light harness in the correct order. The order from the main harness connector, to the rear light harness connector should be; main harness connector, the load equalizer (or signal stabilizer), the Run/Turn/brake module, and then the rear lights harness connector.
I hope this info helps...
bell927
Oct 20, 2024 07:13 PM
GsdGuy
Feb 6, 2023 06:29 AM
JAGlide
Jul 28, 2018 05:59 PM
RodFarmer
Aug 9, 2009 06:52 PM
jhogan20
Mar 10, 2007 10:34 PM
