Semi sintered brake pads
Old Nov 6, 2024 | 02:15 PM
Tileman2692's Avatar
Tileman2692
Delivery has been delayed till Friday eve.
Old Nov 6, 2024 | 07:21 PM
Notgrownup's Avatar
Notgrownup
Patience… they Don’t Just belong in hospitals
Old Nov 7, 2024 | 07:44 PM
Tileman2692
Well got an early delivery of my pads. So I had about 1.5 hrs free time, so . Got them installed and took a 10 min run and used the fronts. It I'm proved my pull nicely. pulled in my garage to inspect the install. My rotors were of coarse very hot . Got a flash light and look at my pads and it seems the pistons aren't completely down or in. I tended to think that the pads a touching the rotor also. Is what I'm seeing sticky pistons? I should probably rebuild the calipers huh? Do you think it's wise to use the bike until I get the kit and rebuild the caliper?
Old Nov 7, 2024 | 08:12 PM
Max Headflow's Avatar
Max Headflow
If the caliper is a 4 piston Kelsey-Hayes, you can pull the pads, jack out the pistons and clean them with a shoelace and clean rag. I generally to that with those calipers when changing pads.. The Brembos don't seem to need it.. Also the aftermarket pads tend to be a little thicker. If the caliper is not centered perfectly, one side may rub.
Old Nov 7, 2024 | 08:27 PM
brakeless's Avatar
brakeless
Don't forget to clean and lube the pins too.
Old Nov 8, 2024 | 05:09 AM
HD_noobie's Avatar
HD_noobie
If you mean pistons retracted, They don't really retract just relax. The pad should always appear to be touching the rotor.
Old Nov 8, 2024 | 06:32 AM
Tileman2692
Thanks guys
Old Nov 8, 2024 | 08:56 AM
Tileman2692
Well the pull is a lot better as for the stopping power I noticed a slight improvement. Definitely not a huge difference but better
Old Nov 28, 2024 | 08:15 AM
Tileman2692
After a few hundred miles they've seated and I do notice a good improvement over the OEM pads with no noise. When I replace the rears I will definitely go semi also
Old Nov 28, 2024 | 10:06 AM
The Gray Wolf's Avatar
The Gray Wolf
From: North Texas in the winter, the Colorado high country in the summer
The dual front brakes on my 2016 Dyna Low Rider are great. I'm still on the original pads. I ride in the mountains of Colorado and in the Sturgis-Deadwood-Custer area of South Dakota. The back brake is, uh...well, I don't even know why Harley put a brake on the rear wheel. It's almost useless.
