Semi sintered brake pads
Old Nov 4, 2024 | 10:42 AM
Tileman2692's Avatar
Tileman2692
Default Semi sintered brake pads
I've always used organic, has anyone made this switch, if so what can I feel or expect. Dynas have not the best brakes and wanted a little more stopping power
Old Nov 4, 2024 | 09:54 PM
Leimy's Avatar
Leimy
I have used them on both my bikes, 2002 and 2017. I love them. A bit noisy but great stopping.
Old Nov 4, 2024 | 11:36 PM
brakeless's Avatar
brakeless
I put some on once and destroyed my polished rotor. Big gouges in it. And noisey too. Went back to organics.
Could have just been a bad set though as others have had good luck.
Old Nov 5, 2024 | 02:37 AM
Stretchman's Avatar
Stretchman
Don't have any first hand experience, so don't take this as gospel, but a lot of the stunt riders are switching their Dynas out for bagger brakes. They seem to bolt right up. I don't know what kind of Dyna you have, but swapping the master cylinder and the lower fork leg for duals might be an option.
Old Nov 5, 2024 | 06:48 AM
TexasScooterTrash's Avatar
TexasScooterTrash
I've been using those pads for around 10 years, on my 07 Dyna and my Wife's 04 1200 C. BIG IMPROVEMENT in braking and works well with OEM rotors.
Old Nov 5, 2024 | 07:10 AM
Notgrownup's Avatar
Notgrownup
I use double sintered pads on all my bikes for years including my 21 trike. It grabs way better that semi sintered and organic pads.
Old Nov 5, 2024 | 10:35 AM
Max Headflow's Avatar
Max Headflow
If your brake rotors pulsate while running organics, go to sintered / semi sintered and after a few thousand the pulsations will be gone. Organic create hard spots but are not hard enough to wear them down.
IMO, the only time you should run organics is on the rear with a thicker disk or if running cheap not hardened rotors.
Old Nov 5, 2024 | 10:43 AM
Tileman2692
Thanks their coming in today when I get hem installed I will be back with comments
Old Nov 5, 2024 | 10:58 AM
Uncle 'B''s Avatar
Uncle 'B'
You're in for a pleasant surprise
Old Nov 6, 2024 | 12:31 PM
Bubba Zanetti's Avatar
Bubba Zanetti
Any update yet?
