I went for a short ride a few days ago, it was about 60 degrees, my battery was fully charged, bike started normally, ran well. After about 15 miles at 60-65 cruising, I pulled over and my idle was slightly higher than normal, not screaming but noticeably high. After maybe 3-4 seconds it dropped to normal idle. It didn't do it again when I got back home (I literally rode 15 mins down the road and back, I was too busy to go for a ride but it was a beautiful day and ...... you know)
The bike is stock (as far as I know) apart from SE air cleaner and V&H short shots. Is this normal, maybe I was on the cusp of an engine temp setting? I've not owned the bike long but not noticed this, even on cold days.
One time I wouldn't worry about, high can be better than low and stalling. My 2007 when I first bought jumped really high a 2-3 times and never did it.
I would wait before I worried. Maybe as you said it was not warmed up. 3-4 seconds isn't that long
And what are were talking slightly high 3-4 seconds? IAgain I would wait file it away and watch. If it happens again you could clean IAC port. Hole behind air cleaner, about 11 oclock, spray sensor cleaner in it when turn bike on and off and cycling kill switch. You should hear a little motor. Atleast this is how it is on my 2007. I have not done this on my 2015 yet, implying yet.
Do you have any codes? You can check codes by holding tripometer in, when turn on bike. But I think you are worrying a little, at least at this point. Check engine light would come on a second time if you have codes.
No codes. I'll see how it goes when I get time/weather to get out again. It wasn't a big deal, just noticeable and unusual. I'll check the IAC for sure, thanks!
With Exhaust and the SE Air Cleaner you need a Tuner! High Idle is indicative of a Lean condition. Its Lean from the Factory and your added parts make that condition worse.
it may well be tuned. It was done at a dealership long ago. Ive only just bought it and its only done it once, although Ive only ridden it a few times
Since you'll be cleaning the IAC you should also check for intake leaks.
The dealer will be able to tell you if the bike has been tuned and which tuner was used.
Unless it was changed resently, I think baring up the wrong tree.
So nothing else has been changed?
I am to lazy, to do much after one time idle flucuation other than watch for a second time. Cleaning IAC is easy, I would google if still the same on 2016s. I kinda doubt a leak on such a new bike, but I guess 8 years is not brand new, but still kinda new for that.
I have never done it, but have heard of taking non lit propane torch and putting it near the seals to see if idle changes. I would look up more before trying. Mechanic told me to use a ciggerette and look for smoke getting sucked in. But at this point I would.
If anything I would clean IAC. For me it usually manifests in a drop in RPMs and then a pick up. I have a tach so I can observe. If going by ear, you may be missing it
No, nothing else has been changed. I was changing handlebars and doing some other stuff today so I took the aircleaner off and looked down the intake. It was quite oily (still got stock breather set up) and there was a deposit ring around the base of the bore where the butterfly shuts to. It easily wiped off but I'm wondering if a bit of that sludge got under the butterfly momentarily. I'll see how it goes.
It doesn't seem like an intake leak, I've dealt with plenty of those. You can just spray a squirt of easy start ( ether ) over the flanges, it'llm soon rev up if there's a leak.
