Mid controls shift lever sticky
Old Mar 30, 2025 | 01:27 PM
Southernspeed's Avatar
Southernspeed
One O rings seals in the inner case hole, the other seals in the inspection plate so you need to move it from 'slot 3' and put it on the outer end of the tube. The old levder rusted up due to not being used. They do tend corrode and get a bit sticky in wetter environments, not much you can do about that except grease it but that attracts dirt. Maybe some dry lube?
Old Mar 30, 2025 | 02:26 PM
Trumpet's Avatar
Trumpet
Coated with never seize paste, like done with axles.
Old Mar 30, 2025 | 02:58 PM
randallissimo's Avatar
randallissimo
Right you are about the other o-ring going to the other end of the sleeve. I figured that out eventually.
I like the never seize idea.
Old Mar 30, 2025 | 08:36 PM
Max Headflow's Avatar
Max Headflow
Use grease.
Old Mar 30, 2025 | 09:10 PM
randallissimo
Too late.
Old Mar 30, 2025 | 09:36 PM
Max Headflow
Originally Posted by randallissimo
Too late.
Then a drop or 2 of motor oil.
Fureek
11
May 16, 2019 12:45 AM
bobbyjoes
Jun 14, 2013 09:44 PM
Oldsarge29
Shovelhead
Jun 11, 2013 07:06 AM
EvilWayz
Ironhead
15
Feb 25, 2010 06:40 PM
Sonny's World
Sep 21, 2009 09:09 AM
