‘11 Wide Glide front brake pad struggle
Old Apr 2, 2025 | 12:44 AM
805dwg's Avatar
805dwg
Default ‘11 Wide Glide front brake pad struggle
Has anybody tried using Galfer pads on ‘11 Wide Glide stock front caliber? I can get them on the clips and in place but I can’t get the center bolt in without it rubbing on the pad. I tried bending the clip tabs on the back of the pads, which helped a little, but not enough. I did notice the back plate is a little bit thicker but I can’t see how that’s why they don’t fit.
Old Apr 2, 2025 | 07:43 AM
TexasScooterTrash's Avatar
TexasScooterTrash
Just pitch that foreign made crap in the dumpster. Get QUALITY, like EBC, Lyndall . . . they ALL FIT.
Old Apr 2, 2025 | 03:36 PM
805dwg's Avatar
805dwg
I thought Galfer was the goto brand since everyone seems to upgrade to Galfer. I’ve used EBC in the past and you’re correct, they do fit. F**k, just wasted $100 (front and rear pads).
Old Apr 2, 2025 | 04:40 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Tossing them into the dumpster is nonsense.
EBC (European Brake Corporation) motorcycle brake components are made overseas, just like Galfer.
I have used Galfer brake pads, they fit perfectly.
Vahomboy
Jan 24, 2021 10:35 AM
06glide02softail
Sep 16, 2017 09:24 AM
tar_snake
Jun 21, 2017 12:58 PM
cmvsm
Feb 7, 2011 10:47 PM
bucs012
May 13, 2008 01:38 PM
