2000 dyna tc88 kickstart
Old May 2, 2025 | 12:09 AM
nghieplk's Avatar
nghieplk
Default 2000 dyna tc88 kickstart
Just borrow the 1008 daytona twintec from my friend to replace the stock ecu on my 2000 fxdl has custom chrome 5 speed kickstart kit installed.
Daytona twintec said their ecu shipped with 0 cranking revs but its still not work. Althought the electric starter is very light - easy to start with the 1008.
Anyone has experienced this before? Should I change something more?
Old May 2, 2025 | 10:55 AM
Max Headflow's Avatar
Max Headflow
Set initial and advance to 5.
Old May 2, 2025 | 05:24 PM
Bubba Zanetti's Avatar
Bubba Zanetti
Old May 2, 2025 | 07:04 PM
Addicted to Chaos's Avatar
Addicted to Chaos
Old May 3, 2025 | 12:43 AM
nghieplk's Avatar
nghieplk
Tried it but still not work…
Old May 3, 2025 | 07:13 AM
TexasScooterTrash's Avatar
TexasScooterTrash
I have the exact same ignition on my Wife's 04 1200 Custom! So I pulled out the setup instructions. MODE - 0 multi spark disabled, 1 multi spark enabled, 2-7 not used. Twintec and Dyna TC88 ignition unit are made for CRANK POSITION SENSOR trigger. There is NO 0 REV SETTING. SO, you have exactly 2 Options. 1 - leave it the way it is, looks cool but useless. 2 - change cam cover to a 1999 model with a NOSECONE IGNITION.
Old May 3, 2025 | 07:11 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Many years ago, someone on this forum was inquiring about a kickstart mod on his Twin Cam. It was determined by a number of folks that the kick start won't spin the engine over fast enough for the crank position sensor to read the flywheel notches. Just my thoughts and memory.
Old May 4, 2025 | 12:59 PM
Max Headflow
There is but it's not a accessible through the switches. You need the programming cable.. As the DTT tech indicted the modules are typically set to 0 revs but someone may have set this one to something other.
Old May 7, 2025 | 08:18 AM
nghieplk's Avatar
nghieplk
Just saw a guy on youtube using thunderheart ignition and it work:
Anyone using thunderheart system for kickstart? If so is there anything else or just “plugnplay” setup?
Old Aug 6, 2025 | 04:28 AM
Carry87's Avatar
Carry87
New Member
Hi,
I found contact to you at V-twin forum from some older posts.
Hi, I purchased used TFCI2 and i received info from Daytona they don't support it anymore which means i can't read map from the bike and i don't have any .dat file that i can start with - can you support me with any .dat file that is for TFCI2 module? I have a dyno on my own so i can fine tune the bike later on - just need a start somewhere
Any info back would be appriciated
joecha56
May 8, 2024 04:18 PM
bigpete1
Motorcycles For Sale
Jan 7, 2019 01:26 PM
volsjp
Nov 10, 2010 10:11 PM
NightTrainJohnny
Sep 16, 2009 10:51 PM
