tmax 6th gear lite
Old Sep 11, 2007 | 06:15 AM
Ace07FXDL's Avatar
Ace07FXDL
Default RE: tmax 6th gear lite
Speedjunkie, do you know if changing the Final Drive Ratio has any negative effects? I'll call Randy at Zippers later as I'm curious if changing the FDR just increases the sensitivity of the TMAX ECM to process the 6th speed indicator or actually results in a performance change.
Old Sep 11, 2007 | 10:02 PM
speedjunkie's Avatar
speedjunkie
I'm not sure on ill effects, but I doubt it. I don't think it changes the sensitivity of the tmax, rather I think it makes it less sensitive. Basically just loosens up the tolerance as to when it can sense the 6th gear switch. Zippers should have a better answer tho.
Mike
Old Sep 11, 2007 | 10:12 PM
cardboard's Avatar
cardboard
You have to admit , for as long as the TM with A/T has been out its doing a pretty good job. I bet as time goes on it even gits better.
Old Oct 13, 2007 | 08:50 PM
harley_jeff's Avatar
harley_jeff
Installed Tmax today and the frickin' 6th gear light doesn't work. It is a new unit - the firmware I loaded was 4.4, I believe. I did the i/net update and that was all that was shown. The unit won't tell you what firmware version it has - or I couldn't figure it out. My settings are FDR 87 and TPS 40. The instructions don't say anything about the -5 on the FDR. I have stock exhaust so I am running map 404. There are only like a couple of FX maps - all the others say FL (for the 96" engine). Any ideas?
Old Oct 13, 2007 | 10:28 PM
cardboard's Avatar
cardboard
Hmmm! It says in the instructions to set the speedo calibrations to 45900 on 06-07 dyna, under basic settings.set final drive to 87, and set gear tps to 40.
Hope you updated yer software and firmware tooo, and hooked up yer auto tune cord to the ecm.
Old Oct 13, 2007 | 11:18 PM
harley_jeff
Yes,I did all of that. It seems to run better. Not like day and night, however.
Old Oct 14, 2007 | 08:00 AM
cardboard's Avatar
cardboard
You just have a base program in. Now your bike needs to be driven so it can tune itself. Were talkin about a lot more than a few hundred miles. your bike will only tune where you ride, so you need to vary yer riding styles.
It will run only as good as what kind of pipes you have on and how you have your bike set up also.
Hope you did not put any anti seize on your oxygen sensors cause it can get on them and mess them up. Take your bike out and ride all day for a few weeks.. The TM will have to read the oxygen sensors and the TPSsensor and rps to tune.
Old Oct 14, 2007 | 04:55 PM
harley_jeff
Got 6th to work.
Reloaded v4.4 - nothing. FDR = 86, no, FDR = 85, no,
FDR = 84 yes!!!!
Mary O
Jul 6, 2013 04:16 PM
ALR24
May 6, 2013 08:50 PM
twistr
Dec 18, 2012 07:41 AM
StuxnetKiller
EVO
Sep 12, 2012 03:27 AM
EMASON01
May 5, 2008 04:12 PM
