Cat removal
Old Sep 2, 2025 | 11:06 AM
Gaffa's Avatar
Gaffa
Default Cat removal
Hi, my 2011 fat bob has the stock exhausts with baffles removed, it also has a SE air filter and back plate and stage 1 map.
I’m thinking of removing the cat as I hate how hot the exhaust gets and I keep burning my leg.
Im guessing the main issue might be it will be too loud and I’ll have no back pressure so will be losing low end torque.
Does anyone know how much louder removing the cat will make it ? And would fitting lollipops or DK Thunder Torque inserts make it quiet enough so as not to be obnoxious, and of course give some helpful back pressure.
Old Sep 2, 2025 | 11:30 AM
nevil's Avatar
nevil
If you were concerned about back pressure you shouldn't have removed the baffles. The Thunder Torque inserts will definitely help in that area, but don't expect too much of a reduction in sound level. It will sound better but it will be anything but quiet.
A good tune will richen things up and cool it down somewhat, so hopefully the one you have is dialed in. You didn't say what map or tuner you have, but if it's the dealer download you can do a lot better with a standalone tuner.
Can't help with the cat removal but I'm sure you'll hear from others here.
Old Sep 2, 2025 | 12:50 PM
Gaffa's Avatar
Gaffa
I didn’t remove the baffles it was the previous owner, hence I can’t refit them
i have the Screaming eagle super pro tuner and cables so i can remap
Old Sep 3, 2025 | 09:30 PM
Roberto88's Avatar
Roberto88
Removing the cat will make it significantly louder and raspier. You will lose some low-end torque without a tune. Lollipops or torque inserts will help reduce the noise and restore some back pressure, but it will still be much louder than it is now. For the heat, consider heat shields or wraps instead.
Old Sep 4, 2025 | 04:42 PM
Chicago Ken's Avatar
Chicago Ken
Funny I removed my cat & couldn't tell a difference in sound, not any louder or deeper. There is a a big difference in heat reduction minus the cat, so it was worth doing.
Old Sep 7, 2025 | 04:09 AM
Gaffa's Avatar
Gaffa
Thanks for the comments, I think I’ll try and find a cheap set of headers and remove the cat from so I can try it and experiment with baffles / lollipops
Old Sep 7, 2025 | 07:26 AM
hd4evr2008's Avatar
hd4evr2008
On my 2012 FXDC the cats were in the mufflers, so just adding slip-ons got rid of the cats.
Old Sep 7, 2025 | 08:35 AM
Gaffa's Avatar
Gaffa
With the Fat Bob the cat is in the headers unfortunately.
Old Sep 8, 2025 | 11:58 AM
O-Town D's Avatar
O-Town D
It's been so long since I did this mod that my memory is a bit "fuzzy." But I seem to recall that I purchased an oem 2008 FB catless header pipe off an online auction site at a good price. Added Rush slip-ons and a PowerVision tuner and my FB runs and sounds great. Just an option you might consider if that year pipe is still available somewhere.
Old Sep 8, 2025 | 12:54 PM
Gaffa's Avatar
Gaffa
What year is your Fatty?
Yeah if I can find some cat less 2008 headers that would be perfect, I can then play with baffles / lollipops and a retune
