risers
Old Sep 7, 2007 | 06:04 PM
bikerdog134's Avatar
bikerdog134
Default risers
anyone know if i can put 4.5in. pullback risers on 05 fxdc. will the speedo wires be long enough . i know the speedo will stand up bu i dont care about that as long as the wires are long enough thanks in advance
Old Sep 7, 2007 | 06:46 PM
Wide Glide 05's Avatar
Wide Glide 05
Default RE: risers
Iknow this info will not help you about your particular model but I installed 4.5 inch Bikers Choice pullback risers on a 2005 WG and the wires were fine as far as my setup on a Wide Glide. I didn't like the pullback part with the WG stock handlebars though, looked funny!Also, with a 2" tank lift installed, the handlebar clamp just touched the speedo housing. SO, I just installed 3-3/4" Drag Specialties straight risers and they look great. The straight risers weigh twice as much as the pull back ones, just for info...
Old Sep 7, 2007 | 08:18 PM
02FXDCustom's Avatar
02FXDCustom
Default RE: risers
I have an '02 FXD, gotta be similar to an '05. I put 4.5" on mine with no problems. You'll have to unscrew your brakeline and push that way up, other than that you'll be OK. Put 24" drag bars on it like mine, then you'll have PLENTY of room and it looks cool, too:
Old Sep 7, 2007 | 09:23 PM
bikerdog134
Default RE: risers
thanks for the feedback ,i put new buckhorns on and the risers should put them just right. when i installed the bars i put a new brake line on that is long enough,in fact when im all done ill have to shorten it. iv been in the garage reworking my seat .got some memory foam and installed it in my seat ,also cut it back so ill sit back almost 3 inches.in the morning i have to glue it in place,do a little shaping and put the cover back on. did a 2 in.tank lift yesterday.got to get seat finished caus the hooters and scoters run is tomorrow.
Old Sep 7, 2007 | 09:27 PM
traveler's Avatar
traveler
Default RE: risers
Wow, cool stuff! You don't mind making/doing your own work!
~Joe
Old Sep 7, 2007 | 10:06 PM
superglide06's Avatar
superglide06
Default RE: risers
02fxdcustom your bike looks great
Old Sep 7, 2007 | 10:13 PM
R Racing's Avatar
R Racing
Default RE: risers
I know with a set of drag bars it will work without having 2 add to your wiring. But you will need a longer clutch cable and brake line.
Jim
Old Sep 8, 2007 | 05:26 AM
soarer 1's Avatar
soarer 1
Default RE: risers
Seems like a bit of confusion, FXDC has speedo in tank panel, FXD has speedo on top clamp.
What model do you have??
I put risers on my 2007 FXDC with the standard Buckhorn bars,
and it looked silly in my opinion.
I tried mini apes, now have Lowrider setup.
No cable issues with any combo mentioned.
Old Sep 8, 2007 | 08:51 AM
DougsDyna's Avatar
DougsDyna
Default RE: risers
I put the HD pullback risers on my 2006 FXDI, with the stock handlebars.
There was no need for any addition wiring or cables. You'll have to straighten the brake line out a little, and find you want to replace it for looks.
DougJ
Old Sep 8, 2007 | 02:08 PM
02FXDCustom
Default RE: risers
ORIGINAL: superglide06
Thanks, bro! Yours ain't too shabby, either! LOVE the pipes on yours.....
Talyon
Dec 21, 2018 08:48 AM
07superG
Sep 20, 2016 04:49 PM
rejlaw
Jan 25, 2008 09:50 PM
Thumper26
Sep 23, 2007 07:34 PM
HANDLER
Jun 6, 2007 05:14 PM
