2008 Dyna Wide Glide dies at stoplights
Old Nov 23, 2025 | 09:59 PM
HDTom's Avatar
HDTom
Originally Posted by Addicted to Chaos
Yeah! I hear ya'.
I have a set of Dyna Manuals that I can immerse myself in if it comes to that.
Originally Posted by Jackie Paper
There is no fuel pressure light nor a code for it.
When you key on, you will hear a apx 2-3 second run of fuel pump that a timer in ECM does.
Then when cranking after apx one turn of motor, ECM gets enough hits from crank sensor next to oil filter, it knows were pistons are and what cylinder do to a slight slow down so timing is established.
Then ECM turn on ignition and fuel pump. Pump runs all the time motor is running. In an event bike is dropped, a bank angle kill switch is in signal system that kills fuel pump.
Signal also monitors signal light bulbs and is the security if bike has one.
You said bike is stock. Does it have a performance tuner?
Yep! The bike is bone stock except for a fancy speedo-tach unit. In addition to the check engine light, there is also a square yellow indicator that lights up with the fuel pump prior to start. Some say they can hear the fuel pump but at this stage of my game, I can't hear the pump. I do have the turn signal/fob security system.
Originally Posted by Tom H
Do a Google or favorite search engine search for how to check for codes on your year and model bike. When you check for codes it "may" show something.
Before you get all wrapped up in alot of suggestions. Check the simple things that have been mentioned.
A on-line manual may be available at the HD web site. Sorry, I don't have a link for you.
Tom
Thanks Tom! I do have the manuals. That's where I read about checking codes without a diagnostic tool. So, unless I'm missing something, I have no codes.
Tom
Old Nov 24, 2025 | 06:09 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Check the speed sensor. They get a little build up on them and they’ll start creating problems like that.
Old Nov 24, 2025 | 07:12 AM
Jackie Paper's Avatar
Jackie Paper
Interestingly what Bubba says.
My use to be old 04 if I started it in gear from a cold start would do that little lug fwd as it broke the oil stuck clutch drive and driven plates.
If it did that, it would mess with where the ECM thought the reference idle should be. Next stop, it would be idling 3 or 4 hundred too high. The only way to fix it was cut it off and and restart it.
I personally have never saw it go the other way however. If it did and was say dropping the idle to 600 or so, that's too low for a FI system to catch itself in transition or probably even to idle.
My 04 alway hunted at least 50 to 75 rpm due to the single pin crank of a two cylinder.
Old Nov 24, 2025 | 07:16 AM
2007 Wide Glide's Avatar
2007 Wide Glide
Have you checked the battery connections? How old is the battery? Might be worth testing it
Old Nov 24, 2025 | 07:20 AM
2007 Wide Glide
With low miles like that, it may have sat with old fuel in it. Maybe put some fuel injector cleaner in the tank. Take the bike on a good long ride and burn a couple tanks of high octane fuel through it.
Old Nov 24, 2025 | 08:35 AM
Max Headflow's Avatar
Max Headflow
Originally Posted by HDTom
All I've done looking for codes is turned the key on and confirmed the check engine light came on for 3-4 seconds then went off and stayed off. Likewise is the fuel pressure light which comes on with key and run switch then goes out after 3-4 seconds. That's usually when I hit the starter.
Does this behavior rule out current active or stored codes and less than adequate fuel pressure?
Tom
It's not fuel pressure. It's engine ECU light. Bike does not have a way to check fuel pressure.
Old Nov 24, 2025 | 08:44 AM
Max Headflow
With low milage, fuel pressure is of concern. There is plenty of time for stuff to rot in the fuel tank.. Invest in a pressure gauge. I'd also check intake manifold sealing. Cleaning the IAC as stated may help..
Old Nov 24, 2025 | 10:11 AM
hattitude's Avatar
hattitude
Tom
That engine light behavior says there are no codes, historic or active.
As Max said, you will get no indications from low fuel pressure.... You'll need a gauge to check that....
Old Nov 24, 2025 | 10:22 AM
Lonewolf176's Avatar
Lonewolf176
Very first thing to try is cleaning the iac.
Old Nov 24, 2025 | 12:39 PM
HDTom's Avatar
HDTom
Thanks Bubba! I'll have to read up on speed sensors.
Thanks for sharing that info. I'm wondering if an unusually long startup may have preceded the dying events.
No, but it's about time I do. The battery is only a year old but while I rotate at 1.5A tender through my other three scooters, the wide glide has a different style (Harley?) trickle charger harness plug than the SAE plugs on my other bikes. So I've been relying on frequent rides on the WG to keep the battery topped up... best I can. I was distracted for a couple of weeks and my last WG ride started with a "weak" start. So, who knows? This dying idle problem could be a battery or battery connection problem..
Good thoughts and advice, for sure. I've put a 1000-1200 miles on it so quite a few tanks of gas. I'll be sure to find and check the fuel filter though.
Thanks to all!
Tom
