Problem solve with me
Old Feb 2, 2026 | 09:06 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Have you checked the fuel pressure? Check for a voltage drop on the main cable at the starter connection.. Seems to crank slowly but then does speed up a little.. Also with a clamp on Amp meter check the starter draw..
Old Feb 2, 2026 | 09:29 AM
misfitJason's Avatar
misfitJason
I am going to check fuel pressure on Wednesday. It’s too cold in a Florida right now (30 degrees). Wednesday it will be 71 again. I highly doubt starter draw is the issue. It is a two year old starter. The cables were upgraded to the nice thick ones when I did the motor build.
Old Feb 2, 2026 | 10:30 AM
steelpony16's Avatar
steelpony16
Could just be the cold weather?
Old Feb 2, 2026 | 10:45 AM
98hotrodfatboy
Yeah bikes don't like to turn over too good in colder temps...
Old Feb 2, 2026 | 11:25 AM
misfitJason
Nope. Did it when it was hot outside too
Old Feb 2, 2026 | 01:29 PM
John CC's Avatar
John CC
Crank it but stop (just) before it starts. Pull a plug. Is it wet or dry?
Old Feb 4, 2026 | 09:07 AM
misfitJason
Update:
Fuel pressure goes to 58 with the key on and falls to fifty. While cranking drops to 30.
Once in and at idle stays at 58 psi
Old Feb 4, 2026 | 10:11 AM
98hotrodfatboy
Did you pull the manual compression releases to confirm they are fully open and not full of carbon??
Old Feb 4, 2026 | 12:14 PM
rigidthumper's Avatar
rigidthumper
Next step would be to verify the throttle blade has about .004" clearance @ 0 TPS, and the IAC pintle (and passageway) is clean.
Old Feb 4, 2026 | 12:16 PM
misfitJason
I had not until you said that. I then did and they are fine
