2003 Dyna Starting Issue
Old Apr 4, 2026 | 04:05 PM
2000emb's Avatar
2000emb
2nd Gear
Default 2003 Dyna Starting Issue
So I have a 2003 Dyna and I’m having issue getting the starter button to work. The run stop switch works just fine. The bike starts by using a starter button on the actual starter its self. I replaced the starter relay with a new one and still nothing. I took apart the hand control buttons and checked the wires from the neck up and no issues. I manually touched the wires together to engage the starter and still nothing. I’m at a loss
Old Apr 4, 2026 | 04:29 PM
Suede Blue Man's Avatar
Suede Blue Man
Originally Posted by 2000emb
..The bike starts by using a starter button on the actual starter its self....I manually touched the wires together to engage the starter .
Who are you really and what do you gain by this?
Old Apr 4, 2026 | 05:48 PM
Tommy C's Avatar
Tommy C
Have the handlebars been changed on the bike?
Old Apr 4, 2026 | 05:55 PM
2000emb's Avatar
2000emb
2nd Gear
What do you mean? I gain hopefully a working starter button haha
Old Apr 4, 2026 | 05:57 PM
2000emb's Avatar
2000emb
2nd Gear
Yes but I checked and have no breaks in any wires up to the first connector
Old Apr 4, 2026 | 07:01 PM
John CC's Avatar
John CC
Does the starter relay click when you press the start button? Do you have a wiring diagram for the bike?
Old Apr 4, 2026 | 07:07 PM
Tommy C's Avatar
Tommy C
Did you check visually, or did you check the wiring with a VOM? The majority of electrical problems on Harleys stem from handlebar or lighting/directional signal changes.
Old Apr 4, 2026 | 07:44 PM
Suede Blue Man
Just wondering if you were the same person who keeps making some false posts about things and you happen to write exactly like them and if you were that person I just wanted to know what they gain from doing so.
So if you are not this person, then welcome to the forum
Often folks' first post is in the welcome section where they say "Hello, I'm (state your name) and I'm a Dynaholic!"
But that's not that big of deal.
We also love pictures of bikes and the bikes issues, like a photo of these two wires you're rubbing together!
What color is your bike and are you able to post photos, we like pictures!
That other person keeps getting deleting.
Old Apr 4, 2026 | 08:45 PM
2000emb's Avatar
2000emb
2nd Gear
No it doesn’t click or make any noises
Old Apr 4, 2026 | 08:51 PM
2000emb's Avatar
2000emb
2nd Gear
I did both but I will say I’m not too sure what I should be looking for when reading with a VOM. Gray wire has 12v, black has 0 and white/black has 0. When I test gray and white/black together it’s got 10 volts which seems weird but maybe that’s normal. I will add that I made a jumper wire from battery to starter solenoid wire (the spade with a green wire) and the bike starts up with that. So I’m leaning towards a problem with my relay and up towards the handlebars. No clicking whatsoever from the relay
