Just went dead
Old Sep 23, 2007 | 11:03 AM
fisherguy54's Avatar
fisherguy54
Default Just went dead
Coming home from a ride and my 04 wide glide just went dead. Checked the fuses, battery, and such still nothing. The fuel pump was humming, the lights were on, but not even a click to try and start. Got a ride home in a trailer. Any one else had the same problem before I talk shop at the dealer?
Old Sep 23, 2007 | 11:15 AM
70mach1's Avatar
70mach1
Default RE: Just went dead
Make sure battery has a charge first .
Then check your electrical conections, must be clean , dry , and tight .
A buddy of mine had a simular problem , while on a ride the engine light came on ,then no turn signals then no speedometer etc.
Thought after replacing the battery it had to be the stator .
Wrong after I checked the stator wires I found the conection to be corroded .
Clean them good and reconected them .
Now battery never goes dead and NO Problems .
my 2 cents...
Old Sep 23, 2007 | 11:48 AM
freebyrd's Avatar
freebyrd
did you try and push start it
Old Sep 23, 2007 | 12:45 PM
SPARKY B's Avatar
SPARKY B
6th Gear
Double check your fuses with a ohmmeter (ringing them out). Same thing happend to me last week. I had lights and pump but nothing when I hit the starter button. I rechecked with the meter and found the bad fuse. I think it was the fuse labled "battery". It is kind of hard to tell by looking at the fuses if there blown.
Old Sep 23, 2007 | 03:13 PM
fisherguy54
I haven't got that far yet. On the road we replaced each fuse with a good one that one of the other riders had. That didn't work. All the fuses had some white corrison on them, so we cleaned them up, maybe too late. Thaks for the help
Old Sep 23, 2007 | 08:11 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
have youchecked the main circuit breaker? it's located behind the electrical (fuse) panel. you mentioned corrosion on your fuses, maybe the main c/b terminals are corroded, the copper stud has the starter wire and silver stud has the ignition switch/voltage regulator connected to it. the c/b usually resets but corrosion may be affecting it.
Old Sep 25, 2007 | 09:48 AM
JRK5892's Avatar
JRK5892
it is very common fora harley battery terminals to get loose, there may be enough power to turn the lights on and not turn the bike over, you should also check your terminals. just my 2c
Bluesrider
Jun 7, 2023 09:38 AM
n4rombl
Apr 7, 2019 08:28 PM
gun smoke
Sep 14, 2018 10:04 PM
bootcampsam
Sep 19, 2016 12:32 PM
Somber Goat
Sep 30, 2008 04:47 PM
