battery fuse keeps blowing
Old Sep 14, 2018 | 01:50 PM
gun smoke's Avatar
gun smoke
Default battery fuse keeps blowing
I had my bike in the garage and it was on a tender and my wife pulled the plug out,i did not notice until a few months later.
The battery was 10 years still ran and started great,I put a new battery in and that's when the problems started,all the accessories worked but still did not kick over.I noticed the one fuse kept on blowing out,it was the battery fuse,is it possible the starter can be stuck because I did not ride it for 3 months and maybe tap on it with a rubber hammer like on a car.Any help be great.
2006 softail/deluxe
Old Sep 14, 2018 | 08:34 PM
gun smoke's Avatar
gun smoke
No speedometer light or turn signals working the15amp fuse marked fuel pump not working checked with my test light.brake lights head lights all good.
Old Sep 14, 2018 | 10:04 PM
b bop n bob's Avatar
b bop n bob
make sure your terminal connections are clean. A bad connection might let the lights work but not sufficient to crank the starter. make sure your wiring isn't pinched somewhere or has rodent damage. Check the contacts on the ignition switch. There is an old joke-'if you can't fix it with a hammer, you got an electrical problem.' but in this case I would refrain from banging on anything. Some bikes won't allow the starter to engage if the bike is not in neutral.
1960lespaul
EVO
41
May 22, 2014 11:27 PM
its_just_me
Jul 19, 2011 07:12 PM
SportyPig
Jun 4, 2010 06:02 PM
kiltiemon
Oct 29, 2008 06:23 AM
